Oil pan gasket
Old 07-05-2013, 05:43 AM
schizm12487's Avatar
Oil pan gasket
Hey, Everyone. I just wanted to ask before I open a can of worms. I need to replace my oil pan gasket (68 Fury 318). It looks like there is enough room to unbolt the pan and remove it without having to disassemble the front end or jack the engine up. Anyone know for sure if it is like that? Just wanted to be sure what I was getting into before I start.
Old 07-05-2013, 07:14 AM
You may have to jack the motor up a tad bit.
Old 07-05-2013, 12:22 PM
You will need to disconnect the tie rods and raise the engine up
Old 07-05-2013, 02:04 PM
moe7404's Avatar
all so on some engines in the 60 you will have to rotate the crank to get the pan off. i dont like RTV. i use permatex #2 item# 80016. it does NOT slip around like RTV.
70roadrunner383
11-14-2014 11:09 PM
TVLynn
10-11-2013 01:36 PM
Mr. Belvedere II
06-21-2012 08:50 AM
tahoeskier
06-18-2011 06:59 PM
dzltd02
10-28-2008 08:25 AM
Quick Reply: Oil pan gasket
