Oil Pan Gaskets
Old Jan 16, 2019 | 04:29 PM
RBLowbucks's Avatar
Oil Pan Gaskets
Has anyone tried ditching oil pan gaskets and just using an RTV sealant to seal the bottom end. I run a deep pan and a windage tray on my 440 and last rebuild I noticed some squishing of one of the oil pan gaskets out the side of the pan. Although I use RTV on the gaskets, I still experienced a leak. I'll be pulling the motor again to fix it, but wondered if anyone has successfully tried just using an RTV sealant without gaskets.
Old Jan 16, 2019 | 05:17 PM
I've always used an adhesive and put the gaskets on the the windage tray and trv on the corners and timing cover.
I'd say you are over tightening the pan and using to much RTV. You could try one of these. https://www.jegs.com/i/JEGS/555/5020...xoCvg0QAvD_BwE
RTV can take out your motor givin the chance, I've seen it happen.
Old Jan 16, 2019 | 05:20 PM
fivepoint's Avatar
Pan Gasket
Summit sells a combination pan gasket/windage tray . Its made with a rubber like material that's designed to reuse. It solved my leak problem.
Old Jan 16, 2019 | 07:44 PM
RBLowbucks's Avatar
Thanks for the info. I like both the windage trays with the molded in rubber seal. Been using the same windage tray for the past 20 years and hadn't seen these before. I think my problem was one of the gaskets I used. I have a habit of stockpiling stuff like gaskets when I can find a good deal on them at swap meets. Have no idea what make gaskets these were, but never experienced a problem with a pan gasket starting to squish out the sides before. Thanks for the info.
Old Jan 16, 2019 | 09:39 PM
These are three of my best friends....
http://gasgacinch.com/
https://www.summitracing.com/search/...c-gasket-maker
https://www.permatex.com/products/ga...asket-maker-2/
Coronet Tom
Jun 18, 2023 07:25 PM
fivepoint
Aug 27, 2017 04:34 PM
schizm12487
Jul 5, 2013 02:04 PM
auerdoan
Aug 25, 2011 12:29 PM
Commando
Dec 8, 2008 01:12 PM
