Question about my 426 Hemi
Old Nov 3, 2020 | 08:57 AM
Bherd's Avatar
Hello, I bought a 36 dodge truck with a 426 hemi in it. It had been sitting since 2012. The guy we bought it from said his dad parked it in 2012 and found out he had cancer and passed. Said something happened on the trans is why he parked it. We checked and the pressure plate was broke so we fixed it and changed the fluids. She fired right up and ran smooth. We shut it off finished putting coolant in it and fired it back up. After about a minute it started puking gravy out of the valve cover vents. My mind says cracked block but someone said could be a cracked head and someone else asked if there is a freeze plug behind the timing cover. Is there one behind there? I'm just trying to think of everything to check and do before I have to pull the motor because it's going to be a task pulling it out of that truck. Sorry so long I just wanted to give what I could about the truck. Any help is greatly appreciated.
Old Nov 4, 2020 | 05:08 AM
Archer's Avatar
B -
It could be as simple as a blown head gasket, but yeah, your going to have to take it a part to find out.
Pull the heads first, that should allow for an inspection of the heads and cylinders. Hopefully, is something obvious and simple. not requiring an engine removal.
Old Nov 4, 2020 | 05:17 AM
Bherd's Avatar
Thank you Archer for the response. We pulled the valve covers and bingo a huge crack in the head. Only bad part is either the motor is going to have to come out to remove it or were going to have to lift the cab. It's crammed in there tight
Old Nov 4, 2020 | 07:34 AM
Archer's Avatar
B -
I'm not really familiar with trucks, but would just breaking the motor mounts and shifting the motor give you enough access?
Big blocks are pretty heavy, so I feel your apprehension.
Good luck and please keep us posted.
Old Nov 4, 2020 | 07:36 AM
Bherd's Avatar
Not without pulling the fender's off I can't shift the motor forward. I'm going to try an post a picture of it for you
Old Nov 4, 2020 | 07:40 AM
Bherd's Avatar
Old Nov 4, 2020 | 02:26 PM
Archer's Avatar
B -
Might just be the angle, but I'm not seeing a problem. The blower assembly naturally has to come off, and once you pull the head bolts, you should be able to remove the heads.
Hardest part might be getting to the header bolts.
The real question might be, what caused the head to crack in the first place.
Old Nov 4, 2020 | 02:28 PM
Bherd's Avatar
I guess I should have said we lifted the valve covers as far as we could to see the head but it won't come off all the way because of the cab. I'm assuming it froze because it sat in a open garage since 2012
Old Nov 4, 2020 | 04:03 PM
fivepoint's Avatar
I would be tempted to pull the motor and do a complete inspection. If it did freeze, there may be other cracks. I would have thought the block would crack before the head. I am wondering if the blower contributed to the head cracking. What else was done to the engine when they put the blower on?
Old Nov 6, 2020 | 03:45 PM
I would say pull the motor and go through it... If its been sitting that long and it has Muck in it... It's going to need a freshen up and some good seals and gaskets to keep from leaking.... Just my 2 cents !!
Looks like a fun project..
Keep us posted--- Cheers
Old Nov 6, 2020 | 03:47 PM
Bherd's Avatar
Thank you. I'll keep posted
Old Nov 6, 2020 | 03:56 PM
I think it easier to find the issue also... Cool truck Im sure...
Old Nov 6, 2020 | 03:58 PM
Bherd's Avatar
Thank you. The truck definitely needs updating lol. We had a little family emergency this week and it's put me behind but I will for sure keep you all updated.
Old Nov 6, 2020 | 04:07 PM
Sounds good..... Hope all works out with the family emergency.... Prayer
Old Nov 6, 2020 | 04:19 PM
Bherd's Avatar
Thank you very much
mr mopar
Sep 26, 2019 07:59 PM
Jetman
May 26, 2019 06:32 AM
MoparDragon1972
Dec 25, 2018 09:44 AM
ritroutt
Oct 17, 2015 09:51 AM
ritroutt
May 24, 2015 06:14 PM
