Should I match the carburetor to the intake by casting#
Old Dec 29, 2021 | 06:59 PM
Scott93307's Avatar
I am looking to put the correct carburetor on an intake manifold I bought. I was hoping someone could tell me if I should be looking for a specific carburetor? The manifold is off a 340 and going on my 72 318. Stock cam with hei ignition (if I can ever figure out the wiring) and headers Thanks for the advice in advance
Old Dec 29, 2021 | 08:03 PM
Carter or a Holley 4150 should bolt on without any issues....
Wiring... Check over at MyMopar.com >>> look in the resources >>>>> Pull up the wiring you need....
Good Luck.... Cheers.... Keep us posted....
Old Dec 30, 2021 | 07:49 AM
Scott93307's Avatar
thank you sir there are hundreds of videos and diagrams to wire the GM hei upgrade but I bought before researching and am installing an hei distributor with an external coil and am having a hard time figuring it out. I wanted to make sure I had it running before I took the intake off and installed the 4 bbl
Old Dec 30, 2021 | 01:35 PM
GM HEI's have the coil built into the distributor cap!
Not to sure what your dealing with at the moment to help or guide you in the rite direction?
http://www.madelectrical.com/catalog/hei-1.shtml
This is what you are referring too?
https://www.summitracing.com/parts/p...hoCf-cQAvD_BwE
If that is the case: All you need is a switched ignition source to the BAT on the cap.... And if your using the tach, Hook your tach signal wire to the TACH on the cap. Then you are ready to run...
Old Dec 30, 2021 | 02:35 PM
Scott93307's Avatar
I bought these to replace the electronic ignition I had in my 72 and I am just trying to make them work
Old Dec 31, 2021 | 09:36 AM
The Distributor looks like one from "A-Team"?
The coil I dont know what kind...Looks like a Ford spin off?
What Box are you going to use?
Old Dec 31, 2021 | 10:46 AM
Scott93307's Avatar
box!! What box? Nobody said I needed a box. I bought these off eBay and am hating them trying to replace the old electronic ignition with this but I should have bought differently.
Old Dec 31, 2021 | 12:07 PM
I want to ask what distributor is that.
Old Dec 31, 2021 | 12:09 PM
Scott93307's Avatar
it’s a JDMspeed distributor I bought off eBay for like 55 dollars but it’s becoming a headache to wire correctly for me.
Old Jan 1, 2022 | 11:49 AM
Oh! So it's one of these "Ready To Run" units?
https://ateamperformance.com/product...28r-coil-wire/
If this is the case: Then you only need to Hook the 2 wires to the coil fro the dist. And wire in the coil without any box....
https://www.jegs.com/InstallationIns..._8387_8386.pdf
Old Jan 1, 2022 | 05:26 PM
Scott93307's Avatar
I spent some time today messing with it I have spark when I wired the coil directly to the battery but it doesn’t even try to start and the whole distributor wobbles when I crank it over. There is a reason it was only 55 dollars im not impressed at all the cap doesn’t even seem to fit tightly
Old Jan 2, 2022 | 08:35 AM
Are you sure you have the Distributor Seated all the way down in the pocket hold? If so, then I would check to see if the shaft is bent, Also now check under the cap and make sure nothing has been damaged?
Old Jan 3, 2022 | 07:19 AM
Scott93307's Avatar
Thanks I found part of the problem. The harness from a 74 had the plugs in different places then on my 72
Old Jan 5, 2022 | 10:30 AM
Lostviking's Avatar
That manifold is for a spread bore carb.
Old Jan 5, 2022 | 10:49 AM
Scott93307's Avatar
Thank you sir I have the adapter plate on the way
CasketKrusher
Oct 25, 2021 06:36 PM
rustyiron1
Apr 14, 2018 07:36 AM
1968GTX
Feb 3, 2014 06:32 PM
74Runneer
Aug 27, 2012 05:49 AM
mopar_go_car
Aug 18, 2009 07:25 PM
