Timing chain sprocket stuck /6
Old Apr 29, 2018 | 10:04 AM
willem_at_work's Avatar
Hi Guys,
I recently set out to replace the timing chain on my 72 dodge coronet with a 225 cui slant six. All went well, untill i got to the sprocket on the crankshaft. this will absolutely not come off! I tried pullers with 2 and 3 arms. Both pullers had the arms bent after. Then i tried together with a friend to pry it of with some pretty long pry bars, but absolutely no movement! Does anybody have a suggestion on how to get this thing off?
regards. Willem
Old Apr 29, 2018 | 11:15 AM
put the three jaw back on it... Shock the sprocket with a drift punch and a big hammer.... Loosen and reset the puller and do the same thing over again.. Should work loose after a few trys..
Use a little good lube like Zep45.
Old Apr 29, 2018 | 11:18 PM
Thanks Bob, i'll get on that as soon as i can and let you know the results!
Also another thing: I recently bought a camshaft bolt for when i need to reassemble, but i can't get the camshaft bolt to go all the way in. Would you have a tip for this too?
regards. Willem
Old Apr 30, 2018 | 07:32 AM
Are you sure you got the rite bolt ? Sounds like you might have the wrong pitch threads ?
Old Apr 30, 2018 | 08:17 AM
Did you mall the treads trying to pull the gear? It happens.
Old Apr 30, 2018 | 09:08 AM
This is the bolt i got: DCC-5249557
Old Apr 30, 2018 | 12:02 PM
Recheck the threads on both... The cam is not drilled that deep.
7/16-14.... ? is the bolt size?
Old Apr 30, 2018 | 01:24 PM
ok, i'll measure it.
From what i know, the bolt i bought was 3/4-16 in.
Old May 1, 2018 | 10:47 AM
Is it safe to stick the sandblaster in there?
Old May 1, 2018 | 11:09 AM
Better to us a bottoming tap to clean it... Sandblaster is not going to fix and thread issues...
Old May 6, 2018 | 02:39 AM
Did exactly what you said, i shocked the socket with a drift punch a couple of times and it came straight off. Thanks bob!
One funny thing though, i found a gasket between the sprocket and the part behind it. Is that supposed to be there?
Old May 6, 2018 | 08:36 AM
No.... But that might raise a little concern.. Keep a eye open for a possible miss alignment issue, when you put it back together.
64dartgt
Oct 8, 2016 10:12 PM
josehf34
Apr 27, 2016 09:35 AM
Gorts 5th
Dec 19, 2012 04:52 PM
roadwarrior86
Oct 11, 2010 11:40 PM
recondotexas
Apr 3, 2010 03:44 PM
