Timing chain sprocket stuck /6
Hi Guys,
I recently set out to replace the timing chain on my 72 dodge coronet with a 225 cui slant six. All went well, untill i got to the sprocket on the crankshaft. this will absolutely not come off! I tried pullers with 2 and 3 arms. Both pullers had the arms bent after. Then i tried together with a friend to pry it of with some pretty long pry bars, but absolutely no movement! Does anybody have a suggestion on how to get this thing off?
regards. Willem
regards. Willem
put the three jaw back on it... Shock the sprocket with a drift punch and a big hammer.... Loosen and reset the puller and do the same thing over again.. Should work loose after a few trys..
Use a little good lube like Zep45.
Thanks Bob, i'll get on that as soon as i can and let you know the results!
Also another thing: I recently bought a camshaft bolt for when i need to reassemble, but i can't get the camshaft bolt to go all the way in. Would you have a tip for this too?
regards. Willem
regards. Willem
Did exactly what you said, i shocked the socket with a drift punch a couple of times and it came straight off. Thanks bob!
One funny thing though, i found a gasket between the sprocket and the part behind it. Is that supposed to be there?
josehf34
Apr 27, 2016 09:35 AM
