Tune up specs, 1940-1953 Plymouth
Old Aug 29, 2013 | 08:42 AM
Shrug's Avatar
Thought this might be useful for somebody.
Old Aug 29, 2013 | 09:12 AM
Thumbs up
Great info! Thanks for sharing!
Old Aug 29, 2013 | 11:18 AM
moe7404's Avatar
do the kids now days even know what cam dwell angle is?
Old Aug 29, 2013 | 01:15 PM
Yes you old fart..... Us wiper snappers know......
Dwell Angle was what it got change to later in life....
Old Aug 29, 2013 | 04:02 PM
moe7404's Avatar
i spent tons of time setting early late 60 duel point dist. i could mount set install and timing set my 1965 300 L points in 15 min. i would set the points with a feeler gauge. and the dwell would be right on 42 degrees. with out a meter. but i have a couple of tricks.
Old Aug 29, 2013 | 08:00 PM
I see.... You had Game back then....
Old Aug 30, 2013 | 09:06 AM
Never used a feeler after the first few times
Just "rough in" by eye, cardboard between one set, set with dwell "on the starter."
Swap the cardboard into the first set of points, crank and set the second, then start 'er up and make sure dwell is OK running.
This of course was easier on an RB with dist up front but it didn't take much longer on a 340
I don't think I spent 5 minutes setting dwell on my 440
Ferds 'n Mopars are easy because of the access to the starter relay. GM you could set stockers running because of the "window" If GM had dual points AND the right dist cap it had TWO windows
What I used to hate working on was the "weird ones" like Mallory Rev Pol or that G$%#@ Da#@ "Ducoil" which fortunately I only ran into about 3 times. Those worked like two separate 4 cylinder engines, two coils one points for each coil, traveling separate paths with a special rotor and cap. The thing is, that changing dwell on one or other sets of points CHANGED THE TIMING on the "other" 4 cylinders!!!
Old Aug 30, 2013 | 09:44 AM
Dammmmmm 440roadrunner had game back in the day also......
No wonder Mopar Won Daytona Beach..And Stock Car...And Super Stock..
And on that note...Who would have thought back then we would be adjusting timing with computers and variable cam timing. Wow... My how times have changed !!!!
Old Aug 30, 2013 | 02:48 PM
moe7404's Avatar
i had a Mallory Rev Pol system. the BAD thing was the points would slip, and you had 4 of the cyl firing at a diff abount. the coil that came with it was very powerfull. i kept it and tossed the Mallory Rev Pol part.
imac08
Oct 31, 2012 09:32 AM
Steffany
Apr 17, 2012 11:42 AM
tonypowell
Jul 8, 2011 10:15 PM
tonypowell
Jul 6, 2011 03:57 PM
76 Doba
Feb 28, 2011 02:15 PM
