What to look for in a 440
Old Sep 20, 2018 | 10:40 AM
Ijohns's Avatar
I own a rolling 73 dart sport and im looking at a 440 with a 727trans on it to put in it . The guy says the 440 only has 27000 original miles on it and its from 71 to 73 came out of a grumman camper and looks complete. It has also been stored in a barn. What should i look for if i go to buy it and how much should i be willing to pay
Old Sep 20, 2018 | 02:08 PM
First get the numbers and letters stamped on the pad to the rt of the distributor, it is possible that it is a 413.
Old Sep 20, 2018 | 02:25 PM
Ijohns's Avatar
These are the numbers from the block. The date onvthe other side is 4-13-7* he cant make out the last number
Old Sep 20, 2018 | 03:10 PM
I would still need to know the information on the pad......
Old Sep 20, 2018 | 03:44 PM
Off to a good start...
Get the combo as cheep as you can. But in the ballpark out this was $800-1000 as long as it turns over and has compression.
Old Sep 20, 2018 | 04:00 PM
Ijohns's Avatar
Im sorry to be a pain what other info on what pad? Im pretty new to this.
Old Sep 20, 2018 | 04:25 PM
413 or 440
Old Sep 20, 2018 | 04:28 PM
I'm not sure the 413 used a diferant casting after 1966 or not. But the pad will tell you exactly what the bb is.
Old Sep 21, 2018 | 01:15 PM
thermoquad is a 70's motor from a motor home so it is a LOW compression motor..doesn't matter if you are planning to rebuild like 8 1/2 to one compression, and most likely a cast crank..
Old Sep 22, 2018 | 12:22 PM
I say $400 if it turns over, most of it would feed the scrapper.
1968_charger_fan@japan
Mar 9, 2017 07:51 AM
hartsnet
Sep 9, 2015 05:50 PM
00DakotaSport
Feb 20, 2015 08:20 PM
mikealp123
Feb 13, 2011 02:07 PM
72challman
Oct 10, 2009 06:33 AM
