What makes it a "smog motor"
Old Nov 9, 2020 | 09:16 AM
jmlee44's Avatar
Shoot - I wrote a whole introduction post and story. I guess I took too long and it signed me out. I'll save it for another time then.
Quick summary.
Original owner of an 86 D350 with the factory 360 in it, 727 auto, 4.10 diff. This truck has never felt "effortless" with power, the way some of the similar vintage chevy's with their 350s (although these were half ton variants, and I think one might have been TBI)...I'm not talking about drag racing speed, but that smooth rush of acceleration that you notice driving around town. My truck struggles to break the rear tires loose unless there's gravel already on the road. But anyway, from what I read this engine is a smog engine and was (per the book) putting out somewhere around 185 peak HP. So maybe this is expected? I feel like it should have a little more GO. Granted it is torquey, but it feels kinda slow - even with the gearing combination it has.
From what I read you can breathe on these motors a bit and get like 300 HP easy, with a good flat torque curve. So I already have a factory dual plane intake on it, factory q-jet. It had smog pumps which were removed and the holes capped off without any noticeable change.
Lately it started burning a bit of oil (although it still ran smoothly), I went ahead and pulled the motor out and have it apart on a stand. Aside from new rings, a good hone and having the heads gone through (since I have to do it anyway) - where can I pickup some good low end power - say upto 4500 RPM to make this feel like a lively engine? What else makes this a "smog" motor? It isn't like some lame 2BBL carb version. I did see dished pistons but what else should I check?
Thanks!
Old Nov 9, 2020 | 09:42 AM
I know exactly what you mean re effortless power on the chevys… drove a friend’s short bed and was admittedly wowed at the low end throttle response. But yeah, that truck is gonna be a dog for sure. I don't know much about those engines in particular but the heads haaaave to be anemic. Decent heads and a cam should wake things riiiight up.
Old Nov 9, 2020 | 09:56 AM
Archer's Avatar
jm -
Typically, besides the smog recycling tubes, you're dealing with a low compression motor.
That's where a lot of power is lost.
On the flip side, you never have to worry about using regular gas.
Old Nov 9, 2020 | 11:11 AM
Build something along these lines and you should happier...
https://www.hotrod.com/articles/buil...t-block-cheap/
dodgem880
Nov 13, 2017 06:34 PM
aknotts
Jan 11, 2013 05:35 PM
willysman69
Jul 10, 2011 09:33 PM
deadkelly
Jan 23, 2010 06:56 PM
rampage_82
Dec 7, 2007 08:22 AM
