45 RH questions
Old 01-17-2013, 08:06 AM
FabioV8's Avatar
45 RH questions
Hello guys,
I have a Land Rover Defender 390 stroker mopar engine and transmission 46RH that use only in off-road, I would install a radiator only for the transmission and delete the passage from the main radiator of the engine, the radiator position it behind the cab as shown in the picture, do you think this kit would be fine?
the kit does not include the check valve can delete it?
thanks
Annulla modifiche
Alpha
Old 01-17-2013, 08:27 AM
If done properly it will work
Old 01-17-2013, 09:13 AM
FabioV8's Avatar
I would like to take this kit
http://www.summitracing.com/parts/der-13950
Old 01-17-2013, 10:42 AM
Gorts 5th's Avatar
Smile
u shouldn't have any issues with that should be more than enough
Old 01-17-2013, 11:12 AM
PK1
PK1's Avatar
More pics!!! That is excellent!! Love to see a discovery with Mopar power. That cooler will work well. Open air install with mechanical cooling too. Nicely done.
Old 01-17-2013, 12:30 PM
FabioV8's Avatar
PK1, that picture is not my defender
the check valve can I remove it?
Old 01-17-2013, 12:46 PM
PK1
PK1's Avatar
Yes. You can remove it.
Old 01-20-2013, 07:01 AM
FabioV8's Avatar
I have another question for you
I redid my 46rh using a kit Trans-scat in Heavy Duty model
http://static.summitracing.com/globa...tci-220500.pdf
my engine does not use an original ECU, and no longer manages the lock-up and the 4th, how can I manage them? I can put two external switches?
the lock-up must operate only when I trigger the switch on the 4th?
LundFish (12-09-2023)
Old 01-20-2013, 07:29 AM
PK1
PK1's Avatar
About half way down the page: http://www.transmissioncenter.net/SwapInformation.htm
Old 01-20-2013, 08:01 AM
FabioV8's Avatar
I had seen this kit, but says that it works only with stock tire size and rear end ratio.
I will use 37 tires and transmission Nissan
I prefer to put two switches if you can
Old 02-27-2013, 12:13 PM
FabioV8's Avatar
Can you tell me where I need to install the thermostat to control the radiator fan?
The output hot is the number 1 or 2?
Thanks
Old 02-27-2013, 04:03 PM
Gorts 5th's Avatar
Smile
fabio you can use two switches and two relays check out my post "
BIG TIME SWAP"
Old 02-27-2013, 04:18 PM
Gorts 5th's Avatar
Smile
i switch in and out of 4th gear all the time
and with the sonax accumulator spring she's quick on the shift....
#618S. 500 / 518 / 618 performance 3-4 accumulator spring. This spring will give you a firm 3-4 shift into overdrive. Cost $7.00
Old 02-27-2013, 05:26 PM
PK1
PK1's Avatar
Install thermostatically controlled sender / trigger for the fan in the intake manifold water passage. Preferably in the front part of the intake near the number 2 cylinder.
Old 02-28-2013, 03:24 AM
FabioV8's Avatar
Gorts 5th,ok I try to look
PK1,so if I understand it I have to connect it to number 1 as in the picture
Old 02-28-2013, 06:01 AM
Gorts 5th's Avatar
Smile
that part is at PACT it looks like you already been to their web page
MoparMan76
01-14-2011 01:31 PM
Quick Reply: 45 RH questions
