'62 727: rear pump/support check ball location
Old Jun 3, 2019 | 12:15 PM
pocale's Avatar
Hi,
I am rebuilding a Chrysler 62 727 tranny. When removed output shaft support from case / rear pump, a check ball fell off and now i cant reason the location.
Pic or link and other help is appreciated. Thanks.
Old Jun 3, 2019 | 07:29 PM
Cast Iron Trans?
I'll try to remember to look when Im in the shop for a picture...
Old Jun 3, 2019 | 08:02 PM
I spent some time today looking for a breakdown but no luck.
Old Jun 3, 2019 | 10:25 PM
pocale's Avatar
thanks for your time guys.
it is aluminium case. push button shifter. drum brake at end of tail housing.
my atsg book does not recognize a rear pump model.
if your documentation does not show a check ball back there i guess it is not necessary.
please comment if some of you have a better view.
i appreciate your help. thanks.
Old Jun 4, 2019 | 09:17 AM
I'm at a disadvantage because I've never worked with a virgin 62 to 64 trans, everything I've had my hands on was I later trans modified to work with the cable shift.
I looked again this morning with no luck.
Old Jun 5, 2019 | 10:10 AM
pocale's Avatar
i got the rebuild parts and started to reassemble -- and found where the steel ball is from:
the ball holds rear pump gear on output shaft.
thanks again for your help
Old Jun 5, 2019 | 03:07 PM
Thanks for coming back and sharing your findings. 👍
Old Jun 7, 2019 | 04:39 AM
I also Did not find the ball for that area... Strange !!!
Glas you found where it went. And thanks for reporting back...
Hope the trans works well when you get it back in. I know folks have shifter issues. Hope you dont run into those !!!
Iamthepreston1
Jan 1, 2017 12:25 AM
catchmeifyoucan
Feb 9, 2014 05:17 AM
willysman69
Feb 9, 2012 04:35 AM
scott2683
Jun 17, 2010 06:25 AM
2002ram440
Apr 21, 2010 11:20 AM
