727 Torqueflite Question
Old Feb 27, 2024 | 01:14 PM
RBLowbucks's Avatar
Anyone know what this plug is inside the bell housing just below the pump cover? Just pulled the pump to replace seals and noticed this plug which also looks to be leaking.
Old Feb 27, 2024 | 01:33 PM
Kuvasz101's Avatar
Never noticed it before. A helpful trick when installing the pump. Place a large elastic band around the outer seal that goes around the pump the night before you drop it in. The seal slips right in without folding over. It's worked good for me.
Old Feb 27, 2024 | 06:01 PM
RBLowbucks's Avatar
Thanks. I do a similar thing only I throw it in the freezer overnight as well. Helps keep the seal compressed until you drop the cover in.
Old Feb 28, 2024 | 05:10 AM
Kuvasz101's Avatar
Great tip!!
Old Feb 28, 2024 | 04:16 PM
Drag Pak's Avatar
Front servo lever pivot access plug.
Old Feb 28, 2024 | 07:11 PM
RBLowbucks's Avatar
Many thanks.
azgr8dad
Nov 15, 2020 04:46 AM
joyner29
Mar 31, 2019 07:46 AM
shone190
Jun 14, 2016 11:38 AM
Dragpnflydf
May 2, 2013 02:17 AM
dgriz13
Aug 4, 2012 09:18 PM
