'74 727 rebuild
Old Mar 2, 2019 | 10:59 AM
Rage607's Avatar
'74 727 rebuild
hi guys,
my '74 (400 cui) newport has started to leak transmission fluid.
I thought, it might be a good idea, to not just reseal it.
Do you guys have some recommendations, what I should do/buy to improve performance and lifespan of the transmission?
Someone changed the bands and the clutches about 10 years ago. But nothing else to improve the transmission.
If something is unclear, I will try to explain. English is not my mothers tongue.
thanks for your help.
Old Mar 3, 2019 | 08:55 AM
A good overhaul kit and add a TransGo shift improver kit should help it. Replace the Convertor while you are at it.
Old Mar 3, 2019 | 09:55 AM
fivepoint's Avatar
If you have not rebuilt a transmission before, its not too difficult. Summit sells a book (HPB-HP1399) that give instruction to rebuild and modify a 727. Its not a job you want to do in the driveway. Work in a clean area.
Old Mar 4, 2019 | 01:34 PM
Rage607's Avatar
Thank you very much for your advice guys.
I actually own that book. I bought it quite some time ago. Nice to know, that I chose the right one to learn about my transmission.
Should I use the transgo tf-1 or the shift kit?
Can you recommend a good overhaul kit.
I often buy from rockauto and ebay because I live outside the US and importing from them is pretty easy.
Thank you guys.
Old Mar 5, 2019 | 08:13 PM
Rock Auto Master Kit should be fine..... I would just get the shift improver kit. Don't go making it shift to hard, it will just cause other maintance issues.
Stay with the TF-1.... Like a Tow-N-Go..
Old May 13, 2019 | 05:21 PM
Rage607's Avatar
Hi Guys.
First off: Thank you for your replies.
I am finally ready to order the parts and want to make sure, that I get everything right.
I'll oder a "big" rebuild kit with bands and the tf-1 shift kit.
I also like to buy a new pan with a screw in it, because mine has a dent.
Is this one ok: pan
There is also a deep variant of the same pan. Is that a better choice? My car is pretty low, so I am afraid it could hit the floor on a bumpy road.
Should I use a magnetic screw?
I still have the stock converter. Should I change that.
My 727 is also missing the flywheel/converter cover on the front and has a selfmade one. What is the name of that plate, so I can buy a new one.
Sorry if my sentences sound harsh. I am not quite used to "talk" in english.
Thank you guys.
josehf34
Aug 1, 2016 08:55 PM
walbey
Sep 24, 2011 03:44 PM
jdewoskin
Sep 10, 2010 06:03 PM
71satellite
Jan 9, 2010 04:44 PM
deadkelly
Apr 19, 2009 04:02 AM
