A727 340 Damper
Old Jun 27, 2016 | 04:24 PM
charger72's Avatar
A727 340 Damper
My 72 charger 340 has the inscription 'use with 340 cast crank' on the front damper. Years ago I had Chrysler replace my transmission. Now I wish I had the original back, but now I would like to put the correct model with the closest date code I can find. Could I get some help on this. I think it would be either the 3515843 or the 3681952. My car was built at Flint on June 01, 1972. It has the rally package. From what I can find on-line it looks like the 3515843 was for early 72 8-340 w/o weight provision, and the 3681052 was 72 8-340 w/damper weight provisions. Does this matter and is the fact my 340 has the cast crank indicate I should go for the damper weight provision 3681052. Does this refer to the torque converter or the trans itself?
Old Jun 27, 2016 | 05:59 PM
Depends on the crank used. Let look at the casting number on the crank and go from their.
Old Jun 28, 2016 | 09:13 PM
the 340 damper note ONLY refers to the engine balance factor Not the trans. Trans should be fine with the different #s Maybe a different converter
Old Jun 29, 2016 | 12:05 AM
64Imperial's Avatar
IDK if this helps but here is a link i seen this this morning when i was doing research has a lot of info on mopar dampers
http://www.440source.com/dampers.htm
~Bret
jimiheadstone
Oct 1, 2013 08:38 PM
gilligan
Mar 9, 2012 06:22 AM
1966DartConvertible
Nov 18, 2010 02:00 AM
Nomadci
Sep 2, 2010 08:13 PM
Juha
Sep 8, 2007 05:35 AM
