Oil level in the gearbox? -59 Chrysler New Yorker
Old Feb 14, 2023 | 03:57 AM
Andersjohansson84's Avatar
Anyone know how much oil goes into the gearbox? I have to change the fluid pan gasket in the gearbox.
Old Feb 14, 2023 | 04:53 AM
Kuvasz101's Avatar
Gearbox? You mean differential or auto trans fluid?
Old Feb 14, 2023 | 05:11 AM
Yes, auto trans fluid.. In Sweden the name is Transmissionsolja (transmission oil)..
My pan in the transmission is leaking so I have a new gasket for it..
Old Feb 14, 2023 | 05:59 AM
Kuvasz101's Avatar
The pan without draining the torque converter holds about 4 quarts. After filling it with 4 quarts run the engine in neutral until hot and check the fluid via dipstick.
Old Feb 14, 2023 | 06:05 AM
Thank you
Old Feb 16, 2023 | 03:51 AM
Originally Posted by Andersjohansson84
Thank you
Stupid question (I haven't checked that closely yet). Where do I add fluid in the gearbox? is it through the dipstick
Old Feb 16, 2023 | 05:43 AM
Kuvasz101's Avatar
No questions are stupid. When putting the pan gasket on "do not use any gasket sealers such as silicone or any material other than the gasket." Do not overtighten. You can always go back after driving it for a short time and retighten. Those transmissions are hard shifting and go into gear abruptly, but they are darn near bullet proof.
Old Feb 18, 2023 | 07:00 AM
Do I add auto trans fluid through the dipstick pipe when I refilling the gearbox??
Old Feb 20, 2023 | 01:02 PM
Kuvasz101's Avatar
Sorry i got carried away.Yes through the dipstick.
Old Feb 20, 2023 | 04:59 PM
yes, there are special funnels for this procedure.
Old Feb 21, 2023 | 11:22 AM
No problem. I found this video and at the end they showed where to fill up.
Old Feb 21, 2023 | 02:48 PM
Kuvasz101's Avatar
Great video! I love that vintage stuff..
Old Apr 28, 2026 | 04:41 PM
zunepuh's Avatar
No questions are stupid. When putting the pan gasket on bmw spares do not use any gasket sealers such as silicone or any material other than the gasket. Do not overtighten. You can always go back after driving it for a short time and retighten. Those transmissions are hard shifting and go into gear abruptly, but they are darn near bullet proof.
Hello. It depends on the gearbox, but most take about 3–5 quarts (3–5 liters) when doing a pan gasket change since you’re not fully draining it.
Andersjohansson84
Jul 4, 2022 07:42 AM
SixBanger
Sep 13, 2018 06:48 AM
srobin1965
May 26, 2018 01:32 PM
jtvisco
Nov 8, 2009 03:38 PM
MarkyMark12345
Apr 10, 2009 06:43 PM
