Rear end question
Old Aug 14, 2012 | 09:37 PM
sfort's Avatar
Rear end question
Looking at a 73 Challenger for sale and wondering is there a place on the car that identifies the type of rear end?
Old Aug 15, 2012 | 02:46 AM
Between the VIN and the fender tag I'm sure that it can be decoded. If you have the numbers, post them up and someone on here will decode it for you.
Old Aug 15, 2012 | 05:36 AM
Archer's Avatar
sfort -
Post a picture of the rear, it should be readily identifiable. See the attached pic.
As for the gear ratio, to may have to test it, since there's no way of knowing if it's stock or not. Fairly simple to ratio the times the drive shaft rotates to the number of times a wheel rotates.
Old Aug 15, 2012 | 06:24 AM
sfort's Avatar
I am trying to figure what the car came with and then figure out what I have.
Old Aug 15, 2012 | 06:27 AM
sfort's Avatar
We have decoded the vin and fender tag. Neither mentioned rear axle. I am wondering if listed as a sport package or something.
Old Aug 15, 2012 | 06:52 AM
Whats the motor and tranny?
Old Aug 15, 2012 | 09:33 AM
Archer's Avatar
sfort -
A little confused. Are you trying to restore it to original or want to know what you have???
You're probably going to have to find the build or broadcast sheet. It's usually under the rear seat, but again, some didn't survive, if the car was hot rodded back in the day.
A lot of those cars didn't stay stock for very long.
Old Aug 15, 2012 | 11:44 AM
Originally Posted by Archer
sfort -
I think its a car that he is looking to buy.
Old Aug 15, 2012 | 09:15 PM
sfort's Avatar
Yes it's a car I am going to buy. It does have the rear seat in it I will look there. The car was a Rally 340 1-4bbl engine with a torqueflight transmission. Since I am going back over to look under the back seat I will look at the rear end to make sure it is an 8 3/4. I want to make sure what gears and wether or not it is a posi as well.
Old Aug 16, 2012 | 06:09 AM
Archer's Avatar
sfort -
Jack the car up from the diff housing and rotate one wheel. If the other wheel rotates in the same direction it's a posi, if it rotates in the opposite direction, it isn't.
Count the number of times the wheel rotates and compare that to the number of times the drive shaft rotates. The ration of shaft to wheel, should be something like 2.73:1, 3.23:1, etc.
Old Aug 22, 2012 | 09:34 PM
sfort's Avatar
It's a 8 3/4 rear end. Have to figure out the ratio next.
Old Aug 24, 2012 | 08:22 PM
sfort's Avatar
We bought it!
Here is a pic of the car. Other than some performance upgrades I am thinking as stock as possible.
Old Aug 25, 2012 | 02:48 AM
Congrads! The car looks good. What are you going to drop in for a drivetrain?
Old Aug 25, 2012 | 09:07 PM
sfort's Avatar
360 crate engine
The car came with a Mopar Performance crate engine. It is the cast iron head version 390HP. My pic will not down load so I will take another and post later. I will be asking lots of questions from the guys on this forum. I found a guy that bought a 70 cuda with a built 318 and he plans to pull the 318 and put a 500+c.i. in its place. I am working a deal to get the accessory bracketry, alt., power steering pump, ac, and radiator. He plans to make the cuda a "hot rod" no power steering or ac.
Old Aug 27, 2012 | 02:33 AM
If you are having issues loading pics, you can always send them to me and I can post them for you. You can also join photobucket (free), load the pics there and post the "IMG" code.
Old Aug 28, 2012 | 12:11 PM
sfort's Avatar
Smile Thanks!
I appreciate the offer. Let me see what I can figure out.
Old Sep 3, 2012 | 02:11 PM
Intragration's Avatar
Cool car. Did you figure out what the gear ratio is? As a Rallye with an 8 3/4 I'm guessing it would have come with a 3.23 or a 3.55. Could have been changed to anything.
Old Sep 5, 2012 | 05:34 AM
sfort's Avatar
No not Yet. But I will. I have been very busy due to a death in the family and being spread very thin trying to get the estate finalized. I have been able to round up a radiator, a/c unit with all the plumbing (working), distributor and electronic box, alt. and all bracketry, p/s pump and steerilg box and a drive shaft. All off a running car. Going to pull it today. The guy is going big block and just wants to get ride of this stuff.
Old Sep 7, 2012 | 05:38 AM
sfort's Avatar
1999 Durango Transmission
I have a 1999 Durango that just became a donor car. It has a 360 Magnum and was running fine before an accident put it put of service. Is the transmission a possible option for my 73 challenger rally project? The engine being put in the Challenger is a 390hp/360/mpp crate motor. Due to the Durango being FI I do know if that is an issue.
Old Sep 7, 2012 | 07:23 AM
You could use the tranny if its a 2wd unit (if not then you would have to get the tailshaft housing swapped) with the Magnum motor but you'll have to swap over part of the wiring harness and the ECM since it is a 46RE (electronic control).
Is the motor you are swapping in a Magnum or LA based? If its a Magnum, you can install an aftermarket (Mopar Performance I think) MPFI intake so that you can keep the FI and not have to hack up as much of the wiring. Not to mention the aftermarket intake will flow much better than the dome style that Dodge went with.
Old Sep 19, 2012 | 08:38 PM
sfort's Avatar
I have taken some pics of the engine we plan to use with my iphone. They are down loaded into my mac but when I try to attach it is failing. ??
Old Sep 20, 2012 | 03:00 AM
They may be too large. The thread in the following link explains how to post pictures.
https://moparforums.com/forums/f62/p...pictures-2128/
Old Sep 20, 2012 | 09:37 PM
sfort's Avatar
Pictures
/Users/steve_fort/Pictures/iPhoto Library/Modified/2012/Sep 19, 2012_2/IMG_1672.jpg
Old Sep 21, 2012 | 02:27 AM
  #24
Send me a PM or an email with the pics and I'll see what I can do.
Old Oct 20, 2012 | 07:09 PM
  #25
sfort's Avatar
Finally got a pic
I think I finally got a picture to down load!
Old Oct 20, 2012 | 10:09 PM
  #26
Easiest is to stick with a carb !! Or switch to an Eldebrock / Holly system for fuel injection. The trans can be made to work, You will have to modify the trans mount, shorten the driveshaft, and adapt the computer
Old Oct 23, 2012 | 07:21 PM
  #27
sfort's Avatar
Is there Some where?
That talks about using these electronic transmissions on carburated engines. I can start with the MPP guys and see what they think about the conversion. I have seen some posts on another site that says to shy away from an automatic on this engine for the street. I realize it is a single plane intake but that can be changed.
Old Oct 24, 2012 | 06:15 AM
  #28
Gorts 5th's Avatar
Talking
the trany swap is as TVLynn say
check out my post the big swap im installing a 518/46re in place of a 727 in my 86 m body found lots of pictures on the web
to day i start the swap this is the second time ive done a swap like this but this is by far the most involved
the od and lu servos i use relays and push buttons im making a custom t handle out of wood for the shifter and im going to install the switches in the handle
check out the other post i got pics and measurements
69POLARA383
Feb 3, 2012 07:43 PM
THE GOOSE
Mar 10, 2011 02:59 AM
71mopar
Dec 12, 2009 07:44 PM
stanhope55
Mar 19, 2009 05:35 PM
72_coronet
Jan 12, 2009 05:57 PM
