replacement 727 dipstick?
Old Oct 13, 2019 | 09:34 AM
droptail's Avatar
the top cap can slide up, and the rubber seal can slide down. was the seal bonded to cap originally? Are the seals available? Was hoping I could buy the stick assembly new but haven't found it.
I prefer to to stick with oe if possible.
Any ideas?
Thanks
Old Oct 13, 2019 | 11:27 AM
droptail's Avatar
I found year one has them. Is there supposed to be a metal washer on one side of the rubber seal - cap on the other?
Old Oct 13, 2019 | 12:00 PM
Sounds like the little tabs broke off the stick itself.
Old Oct 13, 2019 | 02:07 PM
droptail's Avatar
still there but worn down, and the slot in the metal cap has enlarged some. I used a punch to tighten it up for the time being.
what about the any metal washer on the engine side of the cap seal?
Metal cap could slip over top tabs, but not bottom ones. Not realizing the correct cap location, I had been holding the cap on the lower set of tabs while checking lever, but this gives a low fluid reading, which in turn gives rise to over filling.
something to watch out for.
Old Oct 14, 2019 | 01:37 PM
Top::: Cup
Center ::Seal
Bottom:: Small Washer
Tabs on Dipstick>>> Small Washer
Tabs on DipStick>>> Upper Cup
https://www.yearone.com/Product/chry...o[part]/0/
Old Oct 14, 2019 | 02:36 PM
droptail's Avatar
Top::: Cup
Center ::Seal
https://www.yearone.com/Product/chrysler-b-body/fd2951#prettyPhoto[part]/0/
thanks, I couldn't quite get a close up of the assy - I did order this.
Old Oct 15, 2019 | 01:41 PM
dodgem880
Nov 13, 2017 10:51 AM
usaf46270
Jun 13, 2015 05:14 AM
raycan2
Aug 5, 2013 05:22 PM
smallxfires
Jan 24, 2010 08:33 AM
coupe3w
Mar 13, 2008 09:38 AM
