tranny for a 52 Plymouth?
Here's my 2 cents, you should not have a problem doing 50 or better in that car with that eng. and std shift. You have another problem, my guess would a clutch that is slipping very badly causing the eng. to over rev.
An auto trans is not available for that year but there might be a semi auto, meaning one would shift thru the gears once and then be able to start from a dead stop in 3rd gear. MOPAR had these available for Chrysler & Desoto possible for Dodge also.
I have a '42 std shift and can go 50 mph without problem, have also done 70 but don't recommend that but you car should do it without problem
