tranny for a 52 Plymouth?
Old Jul 1, 2013 | 07:51 AM
Shrug's Avatar
OK I got a 52 Plymouth Cranbrook with a 230 ci flathead six.
Is there any auto tranny that could be bolted to this motor without too much effort?
Thanks
Old Jul 1, 2013 | 11:04 PM
I wish Morgan/Legs was here/ She'd be able to give you a defintite answer.
I doubt there is a way to swap in an auto without first swapping in a 31/340/360 LS motor first.
Old Jul 14, 2013 | 10:16 PM
Shrug's Avatar
So anyone? Any ideas? The car is hard pressed to go over 50 without the engine sounding like it is redlining!
Old Jul 30, 2013 | 09:40 PM
42PlyGuy's Avatar
Here's my 2 cents, you should not have a problem doing 50 or better in that car with that eng. and std shift. You have another problem, my guess would a clutch that is slipping very badly causing the eng. to over rev.
An auto trans is not available for that year but there might be a semi auto, meaning one would shift thru the gears once and then be able to start from a dead stop in 3rd gear. MOPAR had these available for Chrysler & Desoto possible for Dodge also.
I have a '42 std shift and can go 50 mph without problem, have also done 70 but don't recommend that but you car should do it without problem
Liu Kang
Dec 2, 2010 08:29 AM
wcturn
Aug 11, 2008 06:59 AM
soulkithchen63
Apr 6, 2008 08:12 PM
ProEmaster
Feb 11, 2008 11:23 AM
318scamp
Apr 20, 2007 09:55 PM
