1970 brake drum removal process
Old Dec 23, 2016 | 05:21 PM
1970ccc's Avatar
How do you remove the front brake drums on a 1970 Belvedere? I took the wheel off and there are what looks like washers that hold the lug bolts to the drum. Is there a nut under the dust cover that I have to remove to take them off or are the lugs part of the drum or part of the hub? I'm a chevy guy turned mopar and the chevy drums come off with the removal of the wheel. Trying to decide f I'm going to tackle the brake rebuild.
Old Dec 23, 2016 | 05:50 PM
There is a spindle nut under the dust cap, pull the cotter key and remove the tin nut cover then the nut.
Old Dec 23, 2016 | 05:52 PM
1970ccc's Avatar
So the lug studs are fixed to the drum?
Old Dec 23, 2016 | 05:53 PM
Yep
Old Dec 23, 2016 | 06:19 PM
Yep.. Thats rite... ...GM took after the Mopars.... Didnt you know that... What GM came up with this on there own.... Naaaaaaaaaa....
Sorry need to rub it in a little....
Just fun'in....
Old Dec 24, 2016 | 04:30 AM
1970ccc's Avatar
Haha no worries! So do you beat the studs out and move them to the new drums or buy new ones?
Old Dec 24, 2016 | 08:15 AM
Press them out and back in... Thats the best way..
Old Dec 24, 2016 | 12:56 PM
1970ccc's Avatar
Thanks for all the help. Just want to be prepared once I start.
-What type brake fluid do I use?
-Will I need a puller to remove the drums?
-Are the rears just like the fronts?
Old Dec 24, 2016 | 02:52 PM
DOT 3
No>
No>
> Just back off the shoe adjuster if the drums do not slid over the shoe.
Luis9995
Sep 29, 2016 07:20 PM
Mike66Newport
May 13, 2011 06:24 AM
Bossta
Oct 6, 2009 09:56 AM
jar84203
Aug 18, 2009 08:21 AM
afastcar
Dec 18, 2008 04:15 PM
