I am stumped with my 85 Ramcharger
Old Sep 9, 2011 | 10:47 AM
dragonmwt's Avatar
I have an 85 ramcharger that was having a problem charging. Well I got that fixed and everything was good for a few months. I parked the truck for about a month and a half and then went out to start it. Would not turn over, no clicking, no lights or horn. Everything pointed to the battery. I charged the battery and still nothing. I put another battery in and nothing still. I went back and started trying to find the problem. If I open the start relay it will turn over. Anyone have an idea where the problem could be? Help please
Old Sep 9, 2011 | 03:08 PM
Can you explain "open the start relay".
Old Sep 9, 2011 | 03:13 PM
dragonmwt's Avatar
The ignition/start relay is in a metal case. If you bend back the tabs you can open it. There is a contact in there that you can depress. If you depress it the starter turns over but the lights and all still will not come on. It is a very strange problem that I am having a hard time figuring out. The bad thing is it is probably something very simple but I just have no idea right now.
Old Sep 10, 2011 | 06:41 AM
Looked at my wirimg diagram and red fusible link that feeds all power to the ignition switch looks like a good place to start. I don't know were it is located. It shows a connector on the left side of the steering column and is not:
black/red: a/c,heater
yellow : start relay coil
black : fuse 4,5,6.
dark blue: fuse 11,12.
pink : charging
grey/black: splice ?
RED : 12V feed to ignition switch.
Old Sep 10, 2011 | 09:34 AM
mr340's Avatar
Yep, sounds like the main feed fusible link bought it.
Old Sep 11, 2011 | 05:25 PM
dragonmwt's Avatar
Thank you for the info. I will check it out and let you know. I hope that is the problem. Thanks again.
Bergmann54
Nov 4, 2013 07:29 PM
Bergmann54
Oct 27, 2013 12:33 PM
89blaster89
Jul 17, 2013 05:15 PM
mr.300
Jul 9, 2011 08:10 PM
Foedoe
May 17, 2011 05:34 AM
