Clear coat polished alum radiator
Polished a alum radiator. Tried to clear coat didn't come out very nice. Any suggestions. Smiths radiator that I bought from doesn't think I should paint it. I thought I would used a high temp which would be higher than the temp would get a 500 degrees. So would there be a issue?
The thing with polished aluminum is there is nothing for the clear to bite to and sooner or later it peels. I have seen a radiator with its tanks powder coted in clear, not sure how long that would last ether.
at the Boeing plant i worked at had a spcail coating so it would stick. regular paints dont stick to AL. the one they used was ugly green color. and was for corrosion protection. dont know of a clear that will work.
There used to be a product like this called Zip seal, but I can't find it.
This looks similar.
http://www.hotrodhotline.com/shineseal-aluminum-sealer
It made polishing less frequent.
This looks similar.
Sealing the tanks would not affect the performance of a radiator, in fact polishing the tanks in the first place would reduce heat transfer more, which the rad company's don't seem to concern with.
I am not concerned about the heat so much as just staying on and looking right. I have already sprayed with a cheaper product and didn't look worth **** so I buffed it back off. That was more work than polishing the first time.
shizam
03-15-2010 12:47 PM
