Clear coat polished alum radiator
Old Mar 16, 2015 | 03:47 PM
Kevin71's Avatar
Polished a alum radiator. Tried to clear coat didn't come out very nice. Any suggestions. Smiths radiator that I bought from doesn't think I should paint it. I thought I would used a high temp which would be higher than the temp would get a 500 degrees. So would there be a issue?
Old Mar 16, 2015 | 07:11 PM
The thing with polished aluminum is there is nothing for the clear to bite to and sooner or later it peels. I have seen a radiator with its tanks powder coted in clear, not sure how long that would last ether.
Old Mar 17, 2015 | 01:22 PM
Kevin71's Avatar
I guess I should get used to polishing it. It looks like chrome right now.
Old Mar 17, 2015 | 01:35 PM
moe7404's Avatar
at the Boeing plant i worked at had a spcail coating so it would stick. regular paints dont stick to AL. the one they used was ugly green color. and was for corrosion protection. dont know of a clear that will work.
Old Mar 17, 2015 | 04:08 PM
There used to be a product like this called Zip seal, but I can't find it.
This looks similar.
http://www.hotrodhotline.com/shineseal-aluminum-sealer
It made polishing less frequent.
Old Mar 17, 2015 | 07:02 PM
The Problem with sealing up an Aluminum anything is you restrict the heat dissipation factors of it purpose.....
Old Mar 17, 2015 | 07:31 PM
Sealing the tanks would not affect the performance of a radiator, in fact polishing the tanks in the first place would reduce heat transfer more, which the rad company's don't seem to concern with.
Old Mar 18, 2015 | 03:37 PM
Kevin71's Avatar
$70 for a small kit to do 40 sqft. Only need about 2 sqft. Has anyone tried this Shineseal?
Old Mar 18, 2015 | 04:01 PM
There website says go to 700 degrees, I'd try it. I used to use zip seal on customer builds, the last one was a $2900 Becool setup for a 55 Chevy.
Old Mar 18, 2015 | 04:33 PM
Kevin71's Avatar
I am not concerned about the heat so much as just staying on and looking right. I have already sprayed with a cheaper product and didn't look worth **** so I buffed it back off. That was more work than polishing the first time.
Old Mar 18, 2015 | 05:51 PM
I think the key word is cheaper, I've never said the stuff was cheap
The cheap stuff turns yellow/brown dull with time and heat.
DRFields
Feb 7, 2013 08:46 AM
72Satellite440
Oct 13, 2010 10:29 AM
Kalaek
Jul 16, 2010 03:48 AM
shizam
Mar 15, 2010 12:47 PM
68 Sat
Oct 22, 2009 02:17 PM
