Engine bay paint recommendations?
Old Dec 26, 2017 | 11:59 AM
Brace21's Avatar
I'm going to do a spray bomb on my firewall, inner fender skirts etc. I don't have the time or equipment to pull the engine so I'm going to work around it for now. Was just wondering what would be the best type/brand of spray can paint to use that requires the least amount of prep work.
Old Dec 26, 2017 | 01:16 PM
I Like Krylon paint myself... Still going to have to clean it good and primer areas....
Just my 2 cents
Old Dec 26, 2017 | 02:25 PM
Archer's Avatar
Brace -
I would use high temp engine paint. I like the Dupli-color or VHT stuff, but most are pretty good.
However, you might be able to find something close to the body color if you go to an auto body supplier.
Most important thing would be make sure the surface is really clean. They ALL require the same prep, if you want it to last.
Old Dec 27, 2017 | 11:26 AM
Brace21's Avatar
Just my 2 cents
Have you used it under the hood where its hot and once its cleaned good do you have to sand or can you use something like wool to rough it up so the paint sticks?
Old Dec 27, 2017 | 11:44 AM
Brace21's Avatar
Originally Posted by Archer
Brace -
We are going to use black on everything, the engine is being done as well in all black parts with polished metal lettering such as edelbrock on the air cleaner and valve covers. Cuda is being pro modded slowly. We just finished reduing the interior in the same color concept, new headliner, dash cap, painted all the plastics, did some carbon fiber on the metal dash parts, new carpets and b&m shifter.
Old Dec 27, 2017 | 06:08 PM
http://www.tcpglobal.com/
Old Dec 28, 2017 | 10:51 AM
Brace21's Avatar
Thanks
Old Dec 28, 2017 | 08:04 PM
Or Eastwood....
http://www.eastwood.com/
JonnySlick
Mar 24, 2017 01:14 PM
JonnySlick
Mar 17, 2017 12:05 PM
raycan2
Mar 5, 2013 06:21 PM
OldChargerGuy
Dec 3, 2012 05:10 AM
ngc414
Jul 15, 2009 06:18 PM
