WTB Mopar 383 Cylinder Heads 346, 452,906
Old May 17, 2014 | 07:05 AM
mrzods13's Avatar
Looking for mopar cylinder heads to buy. Looking for a set that is redone and assembled and looking to spend around $450 - $500 shipped. Want something with hardened seats 346 452 or 906 if the seats were added.
Old May 17, 2014 | 08:54 AM
Try these Guys....
http://cylinderheadexchange.com/home
Old May 17, 2014 | 03:01 PM
I would bet they have a core charge !! It's not going to be cheap.. May even be cheaper to find a motor home engine cheap
Old May 17, 2014 | 03:39 PM
Hahahahahaha...Lynn..... Mopars are never Cheap.....
Old May 17, 2014 | 07:28 PM
mrzods13's Avatar
Would Fel Pro 8519PT1 Gaskets be ok for the heads, buying new bolts, but can't find dowels, don't know if I need them still havent taken the old heads off.
Old May 17, 2014 | 07:40 PM
That number looks like a head set.... But you would have to look it up. I'm not sure of the part number....
However My suggestion will be to look at the cooling holes in the gasket and the heads you get and make sure they match....
Old May 18, 2014 | 03:22 AM
Mr.4spd's Avatar
Right? Why is that? What the crap!
Old May 20, 2014 | 09:53 AM
mrzods13's Avatar
Well I took the heads off today, looks like they put flat top pistons in the block .30. Will the 346 heads still be ok with those.
Old May 20, 2014 | 09:12 PM
moparted's Avatar
IF you ARE HAPPY WITH A 8 to 1 cr
Old May 21, 2014 | 03:07 PM
You would need to check the deck height of the pistons and figure the compression.....
Going back a few years mid 70's I built a 383 ? may have been a 361 LONG time ago...
12 1/2 TRW forged pistons could not get it to stop pinging had to swap to 906 heads to lower the compression-- it worked !!!
mrzods13
May 20, 2014 09:54 AM
mrzods13
Apr 30, 2014 06:37 AM
todd383
Jul 27, 2013 05:04 AM
Newf Wit a 440
Jan 4, 2012 07:02 PM
mach3107
Feb 8, 2011 05:07 PM
