74 dart wheels
Old May 24, 2009 | 10:56 PM
reilly's Avatar
Junior Member
74 dart wheels
Have 1974 dodge dart looking to get a set of rims and tires so i can take it to the track.I have 18's on it now was looking to order the summit star wheels in 15 all the way around.what works good any idea with backspacing and tire size
Old May 25, 2009 | 12:11 AM
What are you running for a motor, tranny and gearing in the rear axle? that will help determine the tire size. As far as which tire to go with, I have heard good things about the Micky Thompson sreet drags.
Old May 25, 2009 | 08:14 AM
2x on everything tim said
the mickey tires also drags look good
my friend got got some
Old May 25, 2009 | 08:18 AM
reilly's Avatar
Junior Member
It has 318 auto disk I don’t know the gears its all stock its not fast or anything but last car I built I wish I would have done a before and after 1/4mi to see the amount of time i picked up with the amount of work did. Getting the 18's to tuck was hard and took too much of my time-money and for sure could tell a diff with the heavy rim and the height makes the gear ratio drop. Would like to make a pass on 15in tires to be fair and avoid the stress if some one can help me with the offset or maybe a set up that works well
thanks yawl
Old May 25, 2009 | 05:30 PM
Crazy4Carz.Com's Avatar
What many people don't understand, The size of the wheel(rim) doesn't make any difference on gears or speedo. The overall size combination of wheel and tire is what makes things change. You can go with an 18 instead of the stock 14 and just get a lower profile tire (shorter sidewall) and everything stays the same (mathematically) I just think the old school look with 15's or maybe 16's and a bigger tire looks right on an older car. I don't care for the "all rim and no tire" look on vintage cars.
Ps, from a southern boy, it is Ya' all, (not yawl) "welcome!
Old May 25, 2009 | 05:33 PM
Steve is right about the wheel size. The only benefit of a larger wheel/rim with the same size tire is that the tire sidewall will be smaller allowing for less roll and better handling. Not a lot better, but it may be noticable.
Old May 25, 2009 | 05:35 PM
X2 and i'm a yankee.
Welcome to the forum
Old May 27, 2009 | 04:39 PM
Old May 27, 2009 | 06:29 PM
Polaradude's Avatar
Welcome to the forum man.
ThomasNieman710
Jun 7, 2013 04:47 AM
Vaprea
Apr 13, 2011 02:42 PM
mytracy
Apr 5, 2011 03:56 AM
Dustoff440
Jan 10, 2011 04:55 AM
fpereira23
Nov 16, 2008 07:42 AM
