Need Advice
Old Aug 5, 2010 | 11:51 AM
metalhead's Avatar
Need Advice
my 67 225 dart is dying on me was tooling around today had been stop and go at stores around town for 2 hr when sitting at a light she died has gas, spark, not overheated, let sit for 15 min and started ran for 5 then died again, plugs are a little carbon fouled like it is running rich. not sure where to go any help is appreciated since this is my daily ride to be used as I fix up
Old Aug 5, 2010 | 02:15 PM
1966sportfury's Avatar
A.K.A Bob Dodge
could be vapor lock, pluged fuel line, (partly pluged)
Old Aug 5, 2010 | 10:20 PM
metalhead's Avatar
thats possible the lines are old and I just finished using the old gas that was in the tank had sat for about 3 months
Old Aug 8, 2010 | 12:04 PM
bootsnbolts's Avatar
how's your carburetor float? needle? the needles can get stuck, causing flood...i went through this one last month. beware a carb fire!
carb issues can also cause plug fouling. also, fouled plugs can cause the stalling.
let her sit for an hour or so then manually pump the accelerator from the engine, watch your carb, check for gas leaks around the bowl gasket. one thing we've done is to whack the carb bowl with a hammer, if the needle is stuck this often frees it up and she'll start again. do not start if there is gas leakage on the exhaust manifold! rinse it off with water or let it evaporate.
are you having any 'surges?' like when you're driving, your engine drops out then lunges?
Old Aug 9, 2010 | 02:28 PM
blue 68 gts's Avatar
Well, theres your problem...
Gas doesn't last as long as it used to now with all the additives they put in...
Throw some FRESH gas in and a set of plugs and you'll be set.
Old Aug 9, 2010 | 03:07 PM
metalhead's Avatar
got good gas, plugs, and changed fuel line, and filter, got valves, timing, and points adjusted feels a lot better
Old Aug 20, 2010 | 09:10 PM
jar84203's Avatar
Member
Sounds like vapor lock to me. If it happens again, I'd try to reroute the fuel lines away from any heat sources.
Old Aug 21, 2010 | 01:10 AM
Archer's Avatar
metal -
The symptoms really sound like vapor lock, but you said you have gas, I assume yo meant that you could see gas squirting from the carb, right?
Humm... how did the points look???
Regarding the old gas and plugs, if you have to let it sit for that long, throw some Sta-bil in the tank.
Old Sep 28, 2010 | 07:59 AM
The make a phenoseal (?) type spacer that disipates the heat from between the intake and carb to keep that from happening. Depending on what RPM range your motor is built for/works in, you can get different spacers ranging from 1/2" to 2" and either single wide open hole design or a 4 hole design.
Rumblefish318
Jun 30, 2013 12:56 PM
TwistedWrenches
May 16, 2009 10:51 AM
3gknuck
May 11, 2009 12:32 PM
moparfection
Dec 16, 2008 07:16 PM
Budro35
Jan 3, 2008 08:47 PM
