ugh carb problems?
Old Mar 30, 2012 | 06:56 AM
71dartswingerdream's Avatar
ugh carb problems?
Ok so I posted on here about a wk ago and got a pretty good answer to my question but would like some collective answers lol. So at part throttle and mostly while going up hill or under load my holley 600 surges. Was told to jet up cuz of a lean condition but would also like to know if it could possibly be a bad cam or dizzy or possibly something else before I go ahead and tear into my brand new carb. Vacuum is at 20hg so I def know its not a leak trans shifts way early. Could this have anything to do with it. Possibly too much load and not enough gas depending on load. Thanx in advance to everyone.
Old Mar 30, 2012 | 08:52 AM
Generally, an ignition problem that would cause something approaching a surge would also cause backfire through the carb
I think this is either a carb or fuel delivery problem
Old Mar 30, 2012 | 01:56 PM
Super easy to do on a Holley. Whatever changes you plan, do one at a time. That will let you know for sure if you have corrected the problem. Too many guys change multiple things and if better still a mystery, if worse then more confusion.
Old Aug 1, 2012 | 11:58 AM
homebrood's Avatar
I do that all the time but usually it fixes the problem and then I don't know what I did that fixed it! Almost as frustrating but not really because it's fixed! Can't learn anything that way though so your words are words of wisdom indeed. Patience is required to follow this philosophy though! I'm lacking in that dept I'll admit!
Tom
Old Aug 1, 2012 | 01:11 PM
FIX your throttle pressure linkage problem FIRST !!!! before you damage the trans !!!!
Old Aug 1, 2012 | 08:04 PM
Could be as easy as a float adjustment. Your fuel level may be too low.
xvodysseusvx
Jun 25, 2018 04:38 PM
dartswinger71
Apr 30, 2012 10:54 AM
northcoasttip
Sep 26, 2011 11:23 PM
Rex 360
Mar 11, 2010 01:39 PM
skimo0104
Dec 6, 2006 04:08 PM
