440 Pulling torque converter to far out
Old May 20, 2020 | 01:27 PM
1986DodgeD150_440BB's Avatar
Hello i have a 86 Dodge d150 i have swapped a built 440 with new 727 transmission and 10 torque converter. My problem is when i start the truck it pours trans fluid out from the front seal. i know its not the seal ive replaced it twice but im starting to wonder if when i bolt it to the flexplate if its pulling it to far out of of the transmission and causing it to leak. here is the flex plate im using https://www.summitracing.com/parts/hup-hp1452 has anyone had problems with these plates?
Old May 20, 2020 | 03:58 PM
What converter are you using?
Old May 21, 2020 | 05:26 AM
How far do you have to pull the converter out to mate with the flex plate?
Old May 21, 2020 | 12:02 PM
its from jegs i got it with the the transmission. the part number is 732-PA13202
Racerhog id say maybe half a inch
Old May 21, 2020 | 04:09 PM
That amount sounds ok.....My suggestion is.... Find someone local with a stock torque converter and measure the snout Diameter. I am thinking the new one is cut down to far...
Also... Thats listed as a 11" @ 2500 Stall.... But that is really besides the point...
If you got the old seal out without damaging it... Check that seal on the converter snout and see if it fits sung?
usedknobby
Dec 1, 2013 08:53 PM
raycan2
Mar 3, 2013 06:14 AM
67Polara
Jul 28, 2012 01:49 PM
Barfly
Mar 21, 2011 03:25 PM
smackhonda
May 26, 2010 07:17 PM
