Dan's 1972 Plymouth Duster
Old Feb 12, 2013 | 05:12 PM
DanK's Avatar
Honestly, it started when I found a '72 Roadrunner for sale. I went into Reliance, TN to look at the car. Met some real good ol' boys, but they were too attached to the car and it was in REALLY bad shape. I couldn't reach a reasonable deal with the guy. The next day I took a look at a '71 demon for sale, but this car was too far gone for me to even make an offer. Floor gone, no engine, mounts cut out... Demons are rare, but no way I could fix this one up. Finally I took a look at this '72 Duster, and the body was awesome. Lines great, no engine, no trans. Previous owner blew the engine because his "mechanic" didn't tighten the oil pan down... ugh! Anyway, he was going to fix it back up, but his mother fell ill and he needed for medical bills. Unfortunately for him, and fortunately for me, his loss was my gain.
I went asking around and found a 360 and 727 tans out of a winnebago for $300. Engine was running when pulled and the trans was rebuild, but never tested because the linkage was wrong. Got it for a steal.
I decided to rebuild the engine to a 408, and have the trans upgraded to include a shift kit, wide kevlar bands, racing clutches and a 2700 stall. Heads went to the shop too, 1.88/1.6 valves to 2.02/1.6 valves. New locks and springs too. The engine I had vatted, bored .030, cleaned, chamfered, new freeze plugs and new cam bearings.
engine before
engine after
Heads before
Heads after
Transmission comes back Monday.
Old Feb 12, 2013 | 05:17 PM
DanK's Avatar
Meanwhile, I was waiting for the engine and trans I started the body work that did need to be done. The trunk pan was in the worst shape, and the driver floor board had a rust hole in it.
Trunk Before
Trunk After
Welded some holes.
Now I'll be working on the floor and dash. Bought a new dash and console, will be fabricating a bezel for the dash this weekend, and hopefully I'll have time to clean and paint the floor too... I'll post more as the build continues!
Old Feb 21, 2013 | 03:03 PM
challenger's Avatar
way to go looks like its getting ready for the road
Old Feb 21, 2013 | 03:38 PM
DanK's Avatar
Transmission is back. Pieces are coming together!
Old Feb 21, 2013 | 04:20 PM
Looks like a short tail shaft trans from a truck ... It looks like it is coming together nice..
Old Feb 22, 2013 | 02:37 AM
Nice build!
Old Feb 22, 2013 | 04:43 PM
DanK's Avatar
Yeah, it's a loadflite from a winnebago!
Old Feb 22, 2013 | 07:12 PM
Gorts 5th's Avatar
Smile
that's going to be a long drive shaft.
do the trany mounts line up?
Old Feb 23, 2013 | 05:58 AM
DanK's Avatar
Honestly, I don't know yet if the mounts will line up. According to all I've read, the case on the 727 torqueflite and the 727 loadflite are the same, so I am assuming they do. I do know that I will have to put a fluid cooler on it, and have a custom drive shaft made.
Old May 22, 2013 | 06:09 PM
DanK's Avatar
Sorry I haven't updated in awhile. I have been working a lot of overtime. I was able to get some more work done though.
Interior stripped, cleaned and painted with rust preventative.
Removed the bumper and grill for refinishing. Removed the fender to realign a saggy door, but realized that the lower hinge needs replacing. So... waiting on more parts.
I'll keep updating... All engine internals are here except the rotating assembly, which is scheduled to come in next Wednesday...
Old May 22, 2013 | 06:56 PM
moe7404's Avatar
fantastic. i couldnt do that much work.
Old May 22, 2013 | 07:27 PM
Buffalojoe426's Avatar
Looks good! Why have I not seen this thread before today? Keep up the good work!
Old May 23, 2013 | 05:03 AM
I'm like Joe.... How did I miss this one???? Great build and thanks for keeping us posted..... Will be watching......and waiting for your next post.....
Old May 23, 2013 | 05:20 AM
Gorts 5th's Avatar
Smile
looking good keep postin...
Old Jun 25, 2013 | 03:59 PM
DanK's Avatar
Painted the Engine, Limelight.
Old Jun 25, 2013 | 07:57 PM
Nice color!
Old Jun 26, 2013 | 08:55 AM
Looks like a conventional 727 truck version, should fit. The loadflight version of the 727 has a completely different pan shape
Old Jul 7, 2013 | 06:06 PM
DanK's Avatar
Comp Cam XE274 Installed
Scat 408 Internally Balanced Installed
KB Hypereutectic Pistons Assembled
Old Aug 4, 2013 | 01:54 PM
DanK's Avatar
Lifters, Pushrods, Heads and rockers assembled....
Old Aug 12, 2013 | 08:52 PM
PURPLE HORONET's Avatar
Cool build,,
Old Aug 13, 2013 | 08:44 AM
looking Good...
Old Aug 17, 2013 | 08:28 PM
69440GTX's Avatar
Sharp car! From looking at the pics I have to ask did you use any cam lube on that top half assembly?
Old Aug 18, 2013 | 10:21 AM
Driveshaft shouldn't be that long ? It's a Duster. Just tell the drive shaft Co you need a heavy duty shaft maybe a 4" tube
Old Aug 25, 2013 | 06:39 AM
  #24
DanK's Avatar
Yeah Tony, I used cam lube. I see in the picture where you would think I didn't though, doesn't show up very well...
Old Aug 25, 2013 | 01:57 PM
  #25
The motor is coming along nicely! Did you have any extra work done to the heads to help with flow?
Old Aug 26, 2013 | 04:22 AM
  #26
DanK's Avatar
Yes. I had them cleaned, ported, polished. The 1.88 valves opened up to 2.02 valves, and lapped them in.
Old Nov 10, 2013 | 04:05 PM
  #27
DanK's Avatar
Haven't posted in awhile. Here's the shape of the engine so far. I think I'm on pace to finish the car by summer!
Old Nov 10, 2013 | 07:21 PM
  #28
Dan...Take a close look at those valve covers.....
They love to hit the intake runner and cause you to chase an oil leak....
I had to use extra think valve cover gaskets to get it sealed....
Looking Very Good...
Old Nov 11, 2013 | 03:53 AM
  #29
DanK's Avatar
Thanks for the heads up. I will definitely make sure I have a good seal.
Thanks!
Old Nov 11, 2013 | 05:17 AM
  #30
DanK's Avatar
RacerHog,
Sure enough, it looks like the covers are sitting on the intake. Again, thanks for the notice. Do you remember which gaskets worked for you?
Thanks!
