1990 D-150 runs rough
Old 07-11-2017, 04:34 PM
gwgdog66's Avatar
1990 D-150 S, 318 TBI automatic. Everything original to truck is still in place.
Last week, my Truck started missing and jerking while driving to work. I got there popped the hood, and couldn't see anything out of normal since it was dark. Before I shut the hood I seen a spark jump where the wire mounts to coil.
Thought ok, in morning I'll pull the wire and make sure its snug befor going home. Did that and it ran like a champ.
Next day same thing happened, no sparks jumping around anywhere this time, so I figured probably time for new cap and rotor.
Did all of that and runs fine until it gets warm and starts missing and jerking while driving and now a noticeable miss when warmed up.
Thought what the heck, scan tool is showing no codes other than 024 which is a cruise control servo code. Truck doesn't have cruise.
So I put a new fuel filter on it and a new coil. Runs perfect, until it gets warm and starts falling on it's face again.
I have scheduled an appointment with a local repair shop next week, but would like to figure it out myself before eating a big repair bill.
Any advice from the experts??
Thanks
Gary
Old 07-11-2017, 08:09 PM
Maybe a defective reluctor in the distributor the ECU might be going bad.
gwgdog66 (07-12-2017)
Old 07-12-2017, 06:55 AM
gwgdog66's Avatar
My skill level on those rule me out.
Thanks
Old 07-13-2017, 09:44 AM
gwgdog66's Avatar
I noticed today that the injector on the passenger side of the truck is making a chug chug chug sound, not the normal hessing sound that a good running throttle body makes.
I checked the spark plugs and number 2 and 6 on the passenger side were black and sooty, 4 and 8 looked normal.
Could an injector going bad cause the engine to run ruff and not set a computer code>>
Old 07-13-2017, 10:47 AM
Yes. The needle inside can hang open or the spring weak....
gwgdog66 (07-16-2017)
Old 07-16-2017, 09:46 AM
gwgdog66's Avatar
I fixed it. I checked the wires going to the sooty plugs, ohm test with my multi meter, then checked the wires going to the good plugs. I had three bad wires. I had the high dollar Taylor wires on it, less than a year old.
Purchased a new set of spark plug wires, put them on, now she is running like a top! :-)
I still have the noise on the one injector, I ordered a pair, and will replace both here in the next week.
Thanks again for all the ideas
Old 07-21-2017, 06:55 AM
gwgdog66's Avatar
i just replaced the injectors. Do I need to disconnect the battery so the computer will not be thinking I still have one bad injector?
Old 07-21-2017, 07:51 AM
No,
You might have to clear all the codes it the heck engine light is Still/Was on.
Old 07-21-2017, 08:21 AM
gwgdog66's Avatar
No,
Thanks,
No codes on the scan tool, and it is running very smooth. I guess I'm good
Old 07-21-2017, 09:59 AM
If I remember correctly the light will go off after so many start and run cycles.
Old 07-21-2017, 03:02 PM
Thanks,
Hehehehehehe.... You are good...
64Imperial
07-02-2016 11:24 AM
jonnyb
10-02-2012 06:55 PM
77Adventurer
13
08-29-2012 10:23 AM
Barfly
04-12-2011 03:43 PM
sgp7679
04-25-2009 11:44 AM
Quick Reply: 1990 D-150 runs rough
