89 D100 318/ 904 tranny
Old Mar 25, 2017 | 04:08 PM
D-cat's Avatar
Considering changing 904 to 727. Can I use the tranny mount crossmember or do I need a new one? The 727 is longer so Will have to make some driveshaft adjustment. Is it just the front yoke sleeve or do I need a different shafts altogether? Of course speedo gear will have to be changed but anything else? I am deleting the ECU & all pollution stuff so will have to have manual kick down & of course torque converter. If I have missed something please help.
Old Mar 25, 2017 | 05:03 PM
All the above sounds correct.... Also, If your going to use the column shifter i think it will take a different linkage rod.
Old Mar 25, 2017 | 07:08 PM
ALL of the linkage should work.. But may I make a suggestion ? If the budget allows go to a 518./ 42re ? an overdrive 727
mi72duster
Mar 7, 2011 06:19 AM
Babs
Oct 9, 2010 12:11 AM
Duece
Aug 25, 2009 07:01 AM
EASTBAYJAY
Aug 3, 2009 12:49 AM
