big block 440 swap
Old Sep 19, 2019 | 05:44 AM
87powerram's Avatar
big block 440 swap
what problems do y'all run into with a big block swap I assume transmission and motor mounts are biggest deal but considering getting a 440 out of my Buddys rv to stuff in a w150
Old Sep 19, 2019 | 07:28 AM
Mounts and brackets, transmission, oil pan and pickup dipstick, radiator are primary part's you need.
Old Sep 19, 2019 | 07:34 AM
87powerram's Avatar
that's what I figured I was going to fabricate a lot of things for it I'm mostly concerned with engine bay room for every thing cause my 318 has a little room and so does my buddies 360 but I'm wondering how much room ill have left for all of the cooling system and that
Old Sep 19, 2019 | 08:27 AM
No problem, they came from the factory with the 440.
Old Sep 19, 2019 | 08:39 AM
This is Spamburgers , a 440 looks small in a pickup.
Old Sep 19, 2019 | 09:29 AM
87powerram's Avatar
what cooling issues will I have should I run 2 puller fans a pusher and puller or 2 pushers or even a mechanical fan I'm not able to leave any motor stock to save my life and done want to kill a 20000 mile 440
Old Sep 19, 2019 | 06:22 PM
SPAMBURGER's Avatar
I’m using a duel electric fan to help with clearance for the billet serpentine pulleys. It’s a flex-a-lite puller with an adjustable temp controller. I’ll get some pics of the fan set up when I get home tonight.
Old Sep 19, 2019 | 07:28 PM
SPAMBURGER's Avatar
Here she is in her current state, don’t mind the dust, I’ve been working on a couple other projects for the last couple years.
You can kind of see the fans, I have them set to come on at about 170F. They seem to do a good job with the little use I have on them.
This pulley set up is the reason for the duel fans. The single was about 1/4 inch into the water pump pulley. With two they kind of straddle it.
Old Sep 20, 2019 | 06:23 AM
87powerram's Avatar
ill trade you my 318 for that whole engine bay lol but where you buy the fans from
Old Sep 20, 2019 | 06:57 AM
SPAMBURGER's Avatar
You can get them anywhere, they are a universal fit.
Old Sep 20, 2019 | 10:47 AM
87powerram's Avatar
how is the fans wired and set to turn on I never have messed with electric fans
Old Sep 20, 2019 | 11:35 AM
SPAMBURGER's Avatar
You can buy a controller separately or some of the fans come with one in a kit. They are pretty easy to wire and set, there are only 5 or 6 wires. Battery + and - keyed power or a switch and power out to the fans, just follow the instructions. Honestly you are quite a ways from needing a fan right now, I wouldn’t worry about it until you are ready. They really are pretty easy.
Blue92w150
Aug 8, 2020 11:06 AM
boeremaboy
Sep 19, 2017 05:54 PM
dr_riedel
Mar 21, 2011 01:26 PM
dobaon22s
Nov 5, 2008 01:42 AM
beep beep 73
Mar 19, 2008 03:00 PM
