Im having carburetor problems???
Old 01-20-2009, 04:07 PM
  #31
mmzullo's Avatar
Check the power valve in the carb.
Old 01-21-2009, 01:14 PM
  #32
how did it turn out greenmachine?
Old 02-01-2009, 03:16 PM
  #34
Polaradude's Avatar
It sounds like your problem develops after you warm up, it really sounds like a vacuum leak after warm up, hows the condition of your intake manifold gaskets ? I hate to suggest this to anyone, but do you know how to check for vac leaks with propane ? I know Iam crazy, its not safe, Mopar forums doesn't suggest using propane, just the crazy Canuck...
Old 02-01-2009, 04:02 PM
  #35
Commando's Avatar
Propane is one of the best ways to check, most of the suggestions I give or have heard given are much safer, but propane is easier.
After the rebuild will it idle cold? If its not idling you may need to adjust the air/fuel mixture.
Old 02-01-2009, 04:09 PM
  #36
Polaradude's Avatar
right on Commando, I always use the propane, just feel worried suggesting that to someone that i don't know or know their mechanical aptitude. but pardon the pun..it's the bomb...
Old 02-01-2009, 10:03 PM
  #37
Commando's Avatar
People are like what the hell are you doing as I move an unlit propane torch around the engine. It's great.
Old 02-02-2009, 03:04 AM
  #39
Polaradude's Avatar
Too funny, people are the same everywhere..hahaha. It's surprising the # of people even gearheads that haven't seen that and they freak....love it. I take the torch tip off and slide on a length of fuel line, then I can pin point the propane.
Old 02-02-2009, 09:40 AM
  #40
Commando's Avatar
Good idea Polaradude.
Old 02-06-2009, 01:41 PM
  #42
Polaradude's Avatar
right on, glad to hear it.
Old 02-06-2009, 02:59 PM
  #43
great
xvodysseusvx
06-25-2018 04:38 PM
doug .A
03-26-2014 02:06 PM
redneckcarl
01-14-2014 05:36 AM
Dominic Torreto
07-20-2012 01:22 PM
69POLARA383
06-26-2012 05:31 PM
Quick Reply: Im having carburetor problems???
