1970 Coronet brake questions
Guest
Posts: n/a
Hi everyone, new guy here. I'm trying to straighten out a brake problem on a 1970 Coronet 9 passenger wagon for a friend. He had someone install a disc brake kit, they finally gave up. The trouble is an extremely hard pedal, very poor braking. What I've determined so far...they didnt bother to install a combination valve, just plumbed from the master directly into the lines. I've obtained the correct valve. Secondly, I see the kit to install the power booster has very different linkage for a factory manual brake car, versus a factory power brake car, leading me to believe I may have a pedal ratio problem. I feel a car like this...a 70 Coronet, 9 passenger wagon, with a 383, power steering, and A/C, would have surely come with power brakes, even though they were drum. The owner insists it had no booster when he got the car, and stopped terrible, even though the brakes were in good shape, and the previous owner "thought" the booster went bad and they just ripped it out. So....my question to you experts, is there any way to tell if this car had factory power brakes? The brake pedal pad has been replaced with a fancy one, so no "power brake" imprint, and the intake was changed to an Edelbrock at some point so no trace of the vacuum port. A vacuum pump was installed by the guy who was fiddling with this, supplying 20 inches of vacuum, so that is not the source of the hard pedal. Thanks for reading this long post.
Guest
Posts: n/a
The kit is from Master Power Brake, they seem like they know what they're doing. The owner purchased the kit for factory manual brakes. Also, this car is made into a Super Bee wagon, obviously a "one of none" clone. Sublime Green, woodgrain, and a wild green and white interior...I'll post pics if anyone would like them.
Guest
Posts: n/a
Actually, you may be suprised.....I saw a sublime superbee wagon at a local car show about 2 months ago. I have some pictures of it, Ill see if i can find them and post them. I donno if they are the same car or not, I didnt think this one is a 383, but I couldnt remember and I wouldnt imagine too many people doing this. So post them up lol
Guest
Posts: n/a
I bought a 1968 Plymouth Sport Satellite wagon off a family friend to do the same. Sadly it's too rusty to restore.
Are you running any kind of big cam in that motor? If so did you check your vacuum levels? I can't really see where you have the power booster's vacuum hose hooked up either.
Guest
Posts: n/a
Unclemike, it DOES have a bumpy cam, and only makes 13 inches at idle, so it has a vacuum pump, set to 20". I also determined that the brand new booster was bad, and it has the wrong master cylinder. I have the new parts, and i'm fiddling with it today.
Guest
Posts: n/a
Hi, rusty. Wrong mastercylinder? My son bought a MPB kit for his 1966 Ply. Satellite, since then they released a kit that uses a four bolt mastercylinder instead of the two bolt set up. Is that what you mean? When I asked him if he was dissapointed he said not as he could use the later Mopar two bolt unit in place of the MPB mastercylinder.
I'm always suspicious of EVERYTHING
Could be bad booster
Wrong master--the drum masters had a little valve in the end of the "kit" that keeps residual pressure, that disk units don't have
Checked the link rod between the master and booster? Too long, to short?
Any chance of some restriction(s) in the lines/hoses?
So far as pedal ration, I'd think that a manual system pedel should have MORE leverage on your booster, not less.
When this stuff was made, people did some funny things with options. I once saw a hemi convertible with A/C, but no radio
The length of that link rod does make a difference, I believe. Cant you adjust some of those. Once , I had bought a new master and put it on. It was so stiff that I broke the retaining pin that holds it in. I then red the instructions that told me that I could adjust that rod. I took the part right back to the store and exchanged it, then adjusted the new one like the directions said. The brakes worked after that.
61 Fury
Mar 14, 2016 04:50 PM
idahoprime
Aug 19, 2010 05:03 AM
the bigedbosky
Jan 17, 2009 05:27 AM
