Alternator question
Old Nov 5, 2008 | 06:05 AM
Commando's Avatar
Could you take a picture, could be a bracket issue or something like that.
Old Nov 5, 2008 | 07:14 AM
you could be missing a spacer or using the wrong bolts. If the pulley is off that much, then don't use it.
What is the car and motor?
Old Nov 5, 2008 | 10:46 AM
Commando's Avatar
Does your bracket look like the one in this picture:
Note that there are three parts to the alternator bracket; 1 the part that bolts to the head, 2 the part that bolts to the piece that bolts to the head and holds the back of the alternator, and 3 the big piece you see the most of that attaches to the 2nd part and the water pump, it has two bolts on the front of the alternator.
From what you are saying it could possibly be rigged without part 1.
Old Nov 5, 2008 | 10:59 AM
Commando's Avatar
That is the front one, and it does not attach to the water pump housing then?
Old Nov 5, 2008 | 11:48 AM
Commando's Avatar
It could be the wrong alternator all together, the harmonic balancer/ pulleys could be wrong. Have you looked up the part number to see if it is correct?
Old Nov 5, 2008 | 12:03 PM
Commando's Avatar
I can look it up, if you post the part number, and the manufacturer if you know it.
Old Nov 5, 2008 | 04:59 PM
challenger's Avatar
the bracket you show in the pic could be the wrong one as there is two different one that look the same but the bolting holes are longer apart , you probably need the longer one to get it up to the farther out hole on the water pump housing or it could be you need the one like c has but we need to know the year of the engine to be sure ok
coronet69
Nov 19, 2013 04:04 PM
69POLARA383
Nov 3, 2011 08:55 AM
chlngr1970
Aug 12, 2009 12:16 PM
mikeynags
Jun 16, 2009 08:19 PM
mikeynags
Jun 16, 2009 06:31 PM
