Best model timing light to do total advance
Old Jan 9, 2014 | 11:06 AM
sendust's Avatar
Hi I just had my 383 rebuilt on my 1967 Satellite, It was burning a bit of oil and was in need of care, All was original except the carb which is a Carter/ Weber competition 600, I had had some issues in the past with fuel supply so to remedy i used a competition pump with a regulator set at 5 3/4 lb. The car ran perfectly with no hesitation. Since the rebuild there has been some hesitation, in the rebuild a more street worthy cam was used producing torque from 1800 to 5500 , i am not sure how much that affects fuel, also when they put the pump back on there was a slight leak so they installed a standard pump that matches the motor, I checked the fuel supply at idle and found 5 3/4 lb. The timing is set at about 12 btdc same as before. I was thinking maybe total advance could be an issue. Any thoughts appreciated.
Old Jan 9, 2014 | 03:03 PM
To do it right A standard timing light works best.. You need to install a timing tape or at least make sure the TDC mark is correct
Old Jan 9, 2014 | 04:49 PM
sendust's Avatar
I have already used a standard light and my tdc mark is well marked including 5 and 10 degree marks on both sides, To get total advance i would need to install a new tape i am not sure how difficult that is, it was recommended i use a timing light with advance dial .
Old Jan 10, 2014 | 02:15 AM
Myraman's Avatar
Light..
I just used an Equus Innova pro last night. Much better than my standard light. Really makes a difference. That model is and advance timing light. I've spent a few hours with my 383 and standard light to no luck at all. That is just one model but it worked well.
Good luck
Old Jan 10, 2014 | 05:51 PM
These are all good ones to use.....
https://www.google.com/search?q=snap...w=1120&bih=622
440 aspen
Dec 21, 2013 09:51 AM
ChristineIII
Dec 7, 2013 07:15 AM
Gorts 5th
Dec 19, 2012 04:52 PM
a.johansson84
May 27, 2012 03:30 AM
Barfly
Jun 9, 2010 08:04 PM
