Dodge 360 Water Leak
Old Nov 23, 2012 | 06:19 PM
Laura Cullen Reynolds's Avatar
I have a rebuilt 360 I have dropped into a 73 Charger SE. I am having an issue with a water leak. On the right (passenger side) front exhaust stud, apparently there is a water port. I keep having a leak. I was told to replace the stud, which I did. Was told to put teflon tape on it to stop leak. I did, but it didn't stop the leak. I was then told to put high temp silicone on it. I did this too but still have a leak.
Any suggestions?
Old Nov 23, 2012 | 07:00 PM
Front and rear stud locations on both sides enter the water jacket. I had the same problem on my Aspen. I got new studs and wrapped the crap out of them with teflon tape and they stopped leaking. If you never want to take them out you could drain the sytem and mix up some JB Weld and pooky the stud and hole with it, let it dry then fill it up again.
Old Nov 24, 2012 | 02:04 AM
Does it leak all the time or just when the motor is warm? Did you have hte heads checked for cracks?
tmatador
Jun 24, 2013 08:26 PM
fastcoauto
Aug 16, 2012 02:08 PM
72D100dodge
Oct 23, 2011 02:58 PM
Achan
Jul 17, 2009 07:34 PM
super commando
Mar 25, 2008 03:12 PM
