electrical problem HELP!!
Old Feb 4, 2009 | 11:54 AM
Polaradude's Avatar
Originally Posted by bpatterson
I have a 67 cornet the tail lights are the problem, I have turn signal lights but no brake or tail lights. There is power to the tail. Any help would be great!!!
Thanks
Silly question time... Fuses ok ? Brake light switch ok ? Check connector on firewall for good connections ? Bulbs not burnt ?
Run a jumper from the battery positive side to brake lights and work backwards from there.
Old Feb 4, 2009 | 07:40 PM
64fury's Avatar
Originally Posted by coronet 440
pretty sure grounds are good.
Don't be pretty sure... be damn sure. for the five minutes it takes redo the ground connections it's well worth it. Also check the bulbs, fuses and connections, could be a break in the wiring somewhere. If it were the brake switch you'd have tail lights, and if it were the Headlight switch you'd have brake lights. The turn lights should be seperate to the tail and brake. Do you have a wiring diagram?
Best of luck!
CE750
Dec 6, 2015 12:15 PM
twindragon6
Jul 18, 2015 06:14 PM
1969_cuda
Jun 20, 2009 04:26 PM
TCPMeta
Mar 28, 2007 04:27 AM
