1968 Plymouth Fury III "water pump housing" and paint
I am calling this part the "water pump housing" until I figure out the actual name for it. I would like to know where I can find one, my local O'Rielly's didn't have one.
Picture of the part (with red arrow pointing to the part):
http://imgur.com/AxFUd0d
The water pump bolts to the front of it and the thermostat is on top. It has two holes on each side that lead back into the block.
Additionally, I was wondering if anyone knows where you can get the original Chrysler turquoise engine paint (Dupont paint code 4799D).
Water pump housing is a good description. You can get an aluminum one at Boulgers sp Mancini Racing There is a difference as too the outlet side. Used to be able to get the paint from Chrysler / Or try Year One or maybe Eastwoods
Before you paint the engine make sure that is the color for the year and engine size. Chyrsler use a few different colors in the same year on different models. Any good parts store will have the paint I got mine through NAPA it was a dupli-color paint and covered and looks great after many coats.
in the old days 1965-1970 the B-RB engines water pumps had to sizes. one with 6 blades for A/C engines. one 8 blades for non A/C engines. sound back wards? chrysler would spin the water pump on A/C engine faster, to get more air through the radiator. so they had to cut back on the water flow. the big trick was to put an A/C water pump on a non A/C engine to gain power. and the belt system was different for each. the pulleys ect, was different sizes.
jnestor
02-23-2011 04:57 PM
