Need help!! 440 BIG BLOCK!!!
Old Oct 18, 2016 | 07:16 PM
  #31
Dakotaguy03's Avatar
Ok so this is gonna make me sound dumb but that big round thing on the front of the engine connected to the crank... pretty sure it's a balancer or a dampener but I can't get it off!!! Urg!!!!
Old Oct 18, 2016 | 07:18 PM
  #32
Need a good size puller...And dont mess up the center threads in the crank....
Old Oct 18, 2016 | 10:08 PM
  #33
What's the name of that thing on the front of the engine though?
Old Oct 19, 2016 | 03:03 PM
  #34
Harmonic Balancer. Use a Harmonic Balancer Puller.
Old Oct 23, 2016 | 05:27 PM
  #35
Haha well I used a puller and got it off, after stripping out all of the threads on the puller....
Old Oct 23, 2016 | 05:44 PM
  #36
Congrats, I can fell the accomplishment in your message.
Old Oct 24, 2016 | 12:57 PM
  #37
Now you can tear it's guts out !!!!
Old Oct 26, 2016 | 06:07 PM
  #38
Well everything is out except 1 piston and the crank, taking the engine to get bored .020 over. gonna cost me $160, and then I'm gonna get a little bit bigger valves. Have them redo the valve seats, get new pistons. Buy some new bearings and few other things and then the engine will be getting out back together
Old Oct 26, 2016 | 07:11 PM
  #39
Need help!!! What's the cylinder bore on my 1978 440 can't find the stock bore.
Old Oct 26, 2016 | 07:43 PM
  #40
3.75
Old Oct 27, 2016 | 01:41 PM
  #41
http://victorylibrary.com/mopar/rb-bs.htm
4.32"
Old Oct 27, 2016 | 05:48 PM
  #42
Don't know what I was thinking, I cut mine 4.38 the first time. Not concerned about cylinder wear.
4.32 is the number.
Old Oct 28, 2016 | 04:23 AM
  #43
Maybe you were just a little "Cranky" that day.
Old Oct 28, 2016 | 04:33 AM
  #44
I was watching the Cubs play so mind was not automotive.
There needs to be a smile for brain fart.
Old Oct 28, 2016 | 04:40 AM
  #45
Now you opened the door for Dyno to put in his wisdom.
Old Oct 28, 2016 | 09:01 AM
  #46
Howdy Y'all.... I see... Soooooooo. We come up with a Dyno-(Me), a Cubs brain fart, an I think your cranky, and a victory library, For a good old 4.32 Bore for the 440 R.B. motor.....
I'm in....
Old Oct 28, 2016 | 09:18 AM
  #47
Thanks guys
Old Oct 28, 2016 | 11:47 AM
  #48
cranky, the guys sarcastically call me smiley, so there, who the #$%^ is cranky.
Old Oct 28, 2016 | 12:24 PM
  #49
Hey Dakota, I'm told there is only one OEM replacement piston now and its the low compression 8.2 piston. You are better off ordering high performance pistons than trying to make the 8.2 compression work. You will have to have your block decked 0.40 and your heads cut to 80 ccs just to get 9.5 to 1 compression = $$$$. So don't buy an overhaul kit, get descent pistons with a compression of 9.5 with a camber of 86 ccs and you will be money ahead.
Old Oct 30, 2016 | 09:14 PM
  #50
Oh yes I never planned on going for oem, I want this engine to have some good power. Gonna go for some dome pistons
Old Oct 31, 2016 | 08:05 AM
  #51
But I still would like this engine to run on pump gas, remember it's streetable.
Old Oct 31, 2016 | 08:12 AM
  #52
Oh and there is one piston that won't come out, and I figured out why... there is metal melted to the cylinder walls. The piston won't go past it...
Old Nov 14, 2016 | 07:33 PM
  #53
Help???
Old Nov 15, 2016 | 04:44 AM
  #54
Picture Might help....
If not... Wire wheel?.... Heat it up to knock the flake off?..... Chisel?....
Old Nov 15, 2016 | 03:25 PM
  #55
Below or above piston?
Old Nov 15, 2016 | 05:25 PM
  #56
It's above the piston and alrighty I'll try those things
Old Nov 29, 2016 | 08:48 AM
  #57
marceloanunes's Avatar
Question 440 fails warm
Hi, guys
I haver a Charger, and the engine fails when it warms up, I'm using a HEI distributor, TSP brand, anyone know of this brand?
Marcelo Brasil
Old Nov 29, 2016 | 09:15 AM
  #58
You should start your own thread instead of interrupting and ongoing one. I'm sure someone can help you out.
Old Nov 30, 2016 | 08:29 AM
  #59
matt1967's Avatar
what car are you thinking of putting the engine in?
Old Nov 30, 2016 | 08:46 AM
  #60
matt1967's Avatar
and also try this link it might help you.... http://board.moparts.org/ubbthreads/...xperience.html
