Summit 185 on 170 off thermostat kit
Is there another spot to put the temperature gauge fitting into besides the water pump housing? I am going to use that spot for the thermostat control for my electric fan. It is a Chrysler 383 B Block. Also I have a 180 degree thermostat and the kit is 185 on and 170 off will that be a problem or would I be better off getting this http://www.summitracing.com/parts/sum-g4959/overview/
for the fan to come on it is the adjustable fan control kit.
If you 'eff around' you might be able to find an aftermarket stat housing that has an additional fitting in the housing. The problem is, the higher you put the sender, then if you get a slow leak, such as overnight, then if the sender becomes "out of water" you might overheat without the gauge indicating. I would be tempted to try and find someplace to tap the housing.
It's been a long time since I fiddled with B/ RB engines, I thought that some years? had additional tappings down there where the temp / heater fittings were.
I was thinking of buying an intake to pair with the edelbrock 1805 650 cfm instead of using the older one off of a 75 Chrysler 400, looking at the edelbrock 2186 and the 7186 or the weiand 8008. The 7186 looks good but I want something that will give good power throughtout the rpm range which all of them claim. What do you think?
For and the street drivers..... Edelbrock Performer intake and a Holley 600 OR 650 OR 750 Fits the bill for me....
For the Performance builds... Edelbrock Super Victor Intake and the Holley 950
Or A Hogan intake manifold and a 1050 Or 1250 Dominator Fits the bill....
Just depends on what your building....
I have a question hooking it up. I want ti to run when the car gets to the temperature I set it at, can I run the positive from the fan to a wire on the starter relay, I put an inline fuse on the pos wire from the fan and I just want to make sure I put it in the right place.
It has been a while cents i have hooked one of those up.
I would recommend hooking it up the way the instructions ask you to. I dont have a copy in front of me sorry.....
If you need I will go find one to give you a hand?
The instructions are not very detailed, I did everything else besides the pos fan wire, the fan works when you hook it to the battery but I do not want it to constanly run, only when it gets to the temp I found the directions http://www.jegs.com/installationinst.../555-52125.pdf
I ran the same setup in my Dart with an electric fan. I ran the ignition on (+12) to the positive of the relay. I ran a ground through the thermostat device back to the ground of the relay. I put the probe inside the return hose to sense the water temp. Set it for 180 degrees. A fused hot straight from the battery to the relay contacts to power the fan.
Hot Rod Valiant
07-16-2012 04:28 PM
1966DartConvertible
08-06-2010 10:03 AM
1966DartConvertible
08-05-2010 08:58 PM
