Summit 185 on 170 off thermostat kit
Old Apr 4, 2014 | 02:47 PM
mrzods13's Avatar
Is there another spot to put the temperature gauge fitting into besides the water pump housing? I am going to use that spot for the thermostat control for my electric fan. It is a Chrysler 383 B Block. Also I have a 180 degree thermostat and the kit is 185 on and 170 off will that be a problem or would I be better off getting this http://www.summitracing.com/parts/sum-g4959/overview/
for the fan to come on it is the adjustable fan control kit.
Old Apr 4, 2014 | 05:45 PM
That the one I run.... I'm am very happy with it....
Old Apr 4, 2014 | 07:14 PM
If you 'eff around' you might be able to find an aftermarket stat housing that has an additional fitting in the housing. The problem is, the higher you put the sender, then if you get a slow leak, such as overnight, then if the sender becomes "out of water" you might overheat without the gauge indicating. I would be tempted to try and find someplace to tap the housing.
It's been a long time since I fiddled with B/ RB engines, I thought that some years? had additional tappings down there where the temp / heater fittings were.
Old Apr 5, 2014 | 06:40 AM
mrzods13's Avatar
You run the 185 170 off or the dry one that goes on the radiator
Old Apr 5, 2014 | 06:41 AM
The Dry one.... Sorry
Old Apr 5, 2014 | 07:02 AM
mrzods13's Avatar
Oh ok I ordered it last night, it was much cheaper and now I dont have to worry about finding a spot, I am returning the other one.
Old Apr 5, 2014 | 07:07 AM
Cool
Old Apr 5, 2014 | 10:51 PM
mrzods13's Avatar
Cool
I was thinking of buying an intake to pair with the edelbrock 1805 650 cfm instead of using the older one off of a 75 Chrysler 400, looking at the edelbrock 2186 and the 7186 or the weiand 8008. The 7186 looks good but I want something that will give good power throughtout the rpm range which all of them claim. What do you think?
Old Apr 6, 2014 | 07:43 AM
For and the street drivers..... Edelbrock Performer intake and a Holley 600 OR 650 OR 750 Fits the bill for me....
For the Performance builds... Edelbrock Super Victor Intake and the Holley 950
Or A Hogan intake manifold and a 1050 Or 1250 Dominator Fits the bill....
Just depends on what your building....
Old Apr 6, 2014 | 08:48 AM
mrzods13's Avatar
68 Newport 383, put a 268H XE Comp cams, springs, lifters, have a 4 barrel edelbrock 650 cfm to go on it.
Old Apr 6, 2014 | 12:22 PM
That should be just fine....
Let us know if it "Pings"
Old Apr 11, 2014 | 08:09 AM
mrzods13's Avatar
I have a question hooking it up. I want ti to run when the car gets to the temperature I set it at, can I run the positive from the fan to a wire on the starter relay, I put an inline fuse on the pos wire from the fan and I just want to make sure I put it in the right place.
Old Apr 11, 2014 | 08:28 AM
It has been a while cents i have hooked one of those up.
I would recommend hooking it up the way the instructions ask you to. I dont have a copy in front of me sorry.....
If you need I will go find one to give you a hand?
Old Apr 11, 2014 | 08:44 AM
mrzods13's Avatar
The instructions are not very detailed, I did everything else besides the pos fan wire, the fan works when you hook it to the battery but I do not want it to constanly run, only when it gets to the temp I found the directions http://www.jegs.com/installationinst.../555-52125.pdf
Old Apr 11, 2014 | 09:13 AM
I would use ignition hot with a keyed source.
Key source two number 2....
Old Apr 11, 2014 | 09:25 AM
mrzods13's Avatar
Could i run it off of a wire on the starter relay
Old Apr 11, 2014 | 11:12 AM
No.... Those are hot all the time or only when the key is in the cranking position.
Old Apr 11, 2014 | 11:47 AM
mrzods13's Avatar
What would be an optimal spot. It's a 68 Newport so not toomany wires
Old Apr 11, 2014 | 12:02 PM
I ran the same setup in my Dart with an electric fan. I ran the ignition on (+12) to the positive of the relay. I ran a ground through the thermostat device back to the ground of the relay. I put the probe inside the return hose to sense the water temp. Set it for 180 degrees. A fused hot straight from the battery to the relay contacts to power the fan.
Old Apr 11, 2014 | 12:07 PM
mrzods13's Avatar
I have the ground set up and the probe directions say to have the pos from the thermostat to 12v source with a inline fuse. Onlyput it to the batt to see if I hooked everything else up right.
Old Apr 11, 2014 | 05:41 PM
Might see if the Acc. Fuse is hot when the key is on... If so use it?
Old Apr 12, 2014 | 08:12 PM
mrzods13's Avatar
The tech from jegs said I could put it on the pos side of the coil and will turn on when the temp gets to where its supposed to.
mrhappy66
Aug 8, 2014 07:43 AM
Hot Rod Valiant
Jul 16, 2012 03:28 PM
1966DartConvertible
Aug 6, 2010 09:03 AM
1966DartConvertible
Aug 5, 2010 07:58 PM
68 Sat
Oct 27, 2008 12:31 PM
