swapping a cam
Old Apr 1, 2009 | 04:05 AM
craveman's Avatar
Senior Member
swapping a cam
how hard of a job is it to put a new cam in a 318. ive never messed with the cam or valves before and was just wondering. i plan on putting a 360 2bbl cam in my fifth ave and i also have ported 302 heads and hopefully soon ill have a 4bbl carburetor if i can make up my mind. or ill just have a bigger 2bbl that i already have on a 4bbl intake manifold.
Old Apr 1, 2009 | 08:30 AM
Its not that hard. Is the cam new or used? You might want to install new bearings depending on how the old cam looks and do something about the lifters.
You can do it in the car but it is way easier with the motor out of it.
Old Apr 2, 2009 | 05:19 PM
what cam and lifters are you going with?
Old Apr 2, 2009 | 06:17 PM
craveman's Avatar
Senior Member
stock 360 2bbl. did they make this in a roller cam and will roller cam add any hp. also to convert to a roller what would i have to do besides changing the lifters.
Old Apr 3, 2009 | 02:28 PM
roller cam gives a little more power (less friction)
you might need new push rods
Old Apr 12, 2009 | 03:56 PM
rr69half6bbl's Avatar
they do make a roller cam setup for it however, itll be exspensive, you need to get adj. pushrods, with the girdles, they started putting rolers in the yorkers after 86. to change the cam you can pull the radiator, then pass the cam form the front of the block back, itll save alot of time and effort to pull the motor, i recomend that you put new cam bearings in ither way, a new cam on old bearings w/ wear spells wiped cam journals early on.
cmetzbower
Oct 1, 2012 03:44 PM
Mudge1
Sep 15, 2012 08:44 AM
MoparMan76
Jan 9, 2011 09:43 PM
bighammer
Apr 10, 2009 11:05 PM
71RR08
Nov 25, 2008 05:40 PM
