Clutch pressure plate swap?
Old Jul 16, 2019 | 09:03 PM
R3NO's Avatar
Hello everyone, I suppose I'll get right into it. I own a 1988 Dodge w250 Power Ram. I rebuilt the motor about a year and a half ago and gave it a nice bit of power from its 160 hp starting point. It currently has (approximately) 465 hp and 750-800 ft lbs of torque. My current clutch pressure plate wont hold that and I'm getting alot of slip at about 1700 rpm to 2300 rpm. Once I pass that point I'm good... assuming I'm on flat ground... any kind of hill and the clutch slips. I cant tow anymore... so frustrating... I'm curious if I can just swap in a gen 1 diesel pressure plate as I know they where rated for about 500hp... I haven't been able to find any material online as to weather this is possible or not... nor can I just find a place that will sell me a pressure plate without having to buy an entire kit. My clutch friction plate is pretty new and buying another to get a pressure plate seems like a massive waste of money. Any help would be great. Thx.
Old Jul 17, 2019 | 04:57 AM
Lots of Diesel Performance Products out there..... Should not have a problem fixing your issue.... But Get the kit, Dont try to piece meal the thing. Thats going to have you chasing you tail !!!!
Just my 2 cents
Welcome to the site...
Old Jul 17, 2019 | 05:50 AM
R3NO's Avatar
Clutch swap...
Thank you for the welcoming... I suppose I forgot to add.. this is a 5.9 360... 4bbl gas motor... just wondering if a diesel pressure plate would work.
Old Jul 17, 2019 | 05:54 AM
The clutch friction plate as you call it is probably toast from slipping, don't bother trying to use it. Spent the money.
Old Jul 17, 2019 | 08:36 AM
Welcome.
Is this turbocharged to make 750 torque? If it’s that much power I would seriously consider a sfi steel flywheel not cast.
Old Jul 17, 2019 | 08:58 PM
Check with one of our site Vendors to see if they might be able to help.....
https://moparforums.com/forums/membe...forceclutches/
Abuong01
Cuda Specific Discussion
Nov 28, 2013 01:26 AM
Kevin71
Feb 1, 2013 07:58 PM
D100Guy
Nov 2, 2010 07:52 PM
hubcap
May 6, 2008 06:26 PM
bigbadsrt
Mar 21, 2008 09:32 AM
