Leaky tranny pan gasket.
Hey guys, what's the best way to seal a leaky 727 gasket? I've tried the cheap rubber ones ... no luck. The pricey moroso rubber ones... no luck. I have a chrome trans-dapt aftermarket pan that I suspect may be my problem. But I may try a cork gasket with some sealant first. I just don't want to suck any sealant into my valve body.Have any of you tried this with success ??
It's expensive, The Late MP trans gasket $25 A hard rubber ? metal reenforced gasket
http://www.ebay.com/itm/46RE-47RE-48...2fad91&vxp=mtr
x2. I use that one. Before you do, drop the pan and put it on the flange and check it for being warped. Ive chased my tail a time or two trying to seal something that was out of shape..
NAPA had the metal reinforced like the MP one with a filter for 42 bucks last time I did mine. Pricey but I dropped it several times to add a temp sending unit and still no leaks.
Ok, seems like a no brainer, but once you're sure the pan is straight, torque the bolts to spec. I had leaky valve covers for a freakin' decade. Then one day I broke out the torque wrench and no more leaks.
Hey Fellas, No luck with "the right stuff". I laid a bead around the inside and outside edges of the pan and it's still leaking but in a different spot now.I bought the cheapy steel pan cause' it had a drain plug. I think i'll switch back to the stock pan and use the nice Moroso gasket i have. The stock pan definitely feels more sturdy than the chrome cheapy. I think the stocker was stamped from heavier gauge steel.Hopefully it will work out. Thanks again for your suggestions.
are you sure its the pan gasket
it could be the o ring at the dipstick tube or the seals at the gear selector / pressure shaft
these leaks can appear to be from the pan gasket these leaks are very difficult to see so pay close attention at these areas also check the speedo o rings jst look for the oil trails
your welcome
the reason i mention this is i had a similar problem turned out to be the selector shaft seals they didn't make a large leak trail they just puddled up on the pan edge and bolts and in my vehicle with the b&m shifter cable bracket i could barely see the trail of oil down the side of the trany. but cool hope it works out for you if it turns out to be the seals i ve got a cool way to change out the seals in the vehicle
Not for sure pic you are wanting to show? A signature pic or a avatar? Info on avatar is here https://moparforums.com/forums/f62/p...pictures-2128/ and this is where my new thread button is:
Upper left below my cursor arrow
70roadrunner383
Nov 14, 2014 11:09 PM
tahoeskier
Jun 18, 2011 06:59 PM
