Oil problems with all OHV engines
Old Jul 20, 2010 | 04:02 PM
  #121
bump
Old Aug 22, 2010 | 08:57 AM
  #122
bump
Old Aug 23, 2010 | 04:04 PM
  #123
Polaradude's Avatar
The big problem clearly lies with no lasagna recipe.
Old Aug 24, 2010 | 11:49 AM
  #124
1972GoldDuster's Avatar
Why can't this just be sticky'd? But anyway about this zinc thing so there is no motor oil you can simply buy at a store that has it? Any additives in particular available at store that has it to add to the oil because I think I'm going to be changing the oil on a 70's 360 and might as well do it right. Is there a particular oil brand that is good too? Synthetic or regular?
Old Aug 24, 2010 | 02:02 PM
  #125
sgp7679's Avatar
castrol gtx has the right amount of zinc and has always worked great for me.
Old Aug 24, 2010 | 03:25 PM
  #126
i run rotella T, but now their even cutting back on the zinc
so, i always use comp cams break in additive
Old Aug 25, 2010 | 02:35 AM
  #127
The only reason why Matt has ~5,000 posts is because of this thread a lone. Take away all the "bumps" and he is just like the rest of us.
Old Aug 26, 2010 | 04:11 AM
  #128
Now that this thread is a sticky, I'm deleteing all the bumps.
Old Aug 26, 2010 | 06:20 PM
  #129
haha
i am hurt guys
Old Aug 26, 2010 | 07:54 PM
  #130
MNMOPAR's Avatar
I just had a engine built and the builder told me to use the Lucas Oils engine break in lube with every oil change. Oreillys carries is in quarts and I just use it with every oil change. I found it to be more reasonably priced than the Royal Purple oil.
Old Oct 4, 2010 | 02:27 PM
  #131
please read from beginning
Old Oct 8, 2010 | 07:55 PM
  #132
In Auto Zone today and found this: http://www.castrol.com/castrol/gener...tentId=7032644
Is that a good oil wieght to put in your car? Really expensive, almost as much as Royal Purple so probably wont be getting anyway. Just letting you know.
Old Oct 9, 2010 | 11:58 AM
  #133
that weight is ok
but, if it is synthetic, unless your motor is sealed up tight, any leak that you have now will be look magnified if you put synthetic oil in
Old Dec 7, 2010 | 01:56 PM
  #134
bump
Old Jan 9, 2011 | 07:50 AM
  #135
bump
Old Feb 19, 2011 | 01:06 PM
  #136
Old Apr 6, 2011 | 08:40 AM
  #137
moparman63's Avatar
I have been talking to several camshaft companies about this and they all agree that the only time the zinc is needed is at camshaft break in. Of course, it does not hurt a thing to run oil with zinc for the life of the engine, but it may be an unnecessary expense.
Old Apr 7, 2011 | 04:01 PM
  #138
I have found that flat tappet engines need zinc. Maybe a stock running motor with no real spring pressure can get away with less zinc. But, the higher the spring tension, the more zinc you need.
Since these cars only require one to two oil changes per year, adding the zinc for extra security is the safe route.
Old May 10, 2011 | 02:29 PM
  #139
bump
Old May 23, 2011 | 01:31 PM
  #140
bump
Old Jul 13, 2011 | 05:03 PM
  #141
bump
Old Jul 16, 2011 | 11:04 PM
  #142
3404speed's Avatar
this thread would be a page or two long without all the fluff...what was the original Q?
Old Jul 17, 2011 | 07:07 AM
  #143
I bump the page so it remains near the top in the general discussion thread page. This thread is warning people about the danger of not having enough zinc in one's oil.
Old Jul 20, 2011 | 01:13 PM
  #144
duster_066's Avatar
Not trying to advertise for this outfit, but it explains the problem well including the counter argument. It's worth a look.
http://www.zddplus.com/
Old Jul 21, 2011 | 04:03 PM
  #145
I agree with the article. The counter arguement of an engine that has been in use for a long time will need less zinc may be true, but for an extra $10, I'd feel a lot safer if I always used the additive.
Old Jun 19, 2012 | 04:10 PM
  #146
Gorts 5th's Avatar
its true no zinc faster wear comp cams has oil with zinc or use a break in additive like lucas and there is a off brand name oil i cant think of the name but its sold at wallmart the machine shop that did my motor recommended this brand oil because it contains zinc i ran it during the break-in period but went back too Valvoline 20/50 zr racing now i put the zinc additive in with my oil change i had no ideal they removed the zinc and all the warnings that came with my comp cams about this educated me and saved me a lot of money i trust Valvoline ran that oil for ever in all my vehicles and the tear down of my last souped 318 proved to me of the protection and cleanliness of the parts wow
Old Jun 19, 2012 | 04:18 PM
  #147
Gorts 5th's Avatar
also for a quick note castrol gtx is junk in my experience i tried it for a year in my work van and i would notice oil pressure drops when that oil would get hot more than way more than Valvoline if i would park the van for about an hour say to get lunch then back to the job sight the oil pressure would be higher i didn't like this variable i never ran this oil in my high horse power motors probably a good thing
Old Jun 19, 2012 | 04:26 PM
  #148
Gorts 5th's Avatar
oh yea leave it to the epa to do such a thing planed obsolescent? they do that to wear you r engine out sooner not to protect emission control sensors ?
Old Jun 20, 2012 | 08:54 AM
  #149
Gorts 5th's Avatar
Rotella oil has zinc also my machine shop recommended this brand oil but i still use Valvoline and use zinc additive
Old Jun 22, 2012 | 03:13 PM
  #150
I heard that rotella was cutting back the zinc that they had in the oil
