tranny trouble
Old Sep 2, 2012 | 07:31 AM
smartymouse's Avatar
tranny trouble
had a slght leak and on my way to the shop it stared smoking bad and went out, it won't shift into drive for a few seconds then goes out right away, it has a reverse manual valve body and a b&m quick sliver shifter it was raced and i'm going to convert it back to a fully auto its headed for the tranny specialist to have the work done, bt i'm wondeing if i'll have to change shifters or can this one work? i'm hoping the problem is the valve body which i'm changing anyhow, anybody know what my problem could be?
Old Sep 2, 2012 | 08:07 AM
If it was raced, takes a few seconds before drive kicks in it sounds like the tranny is in need of a full rebuild. You will have to swap shifters if you go to a normal shift valve body.
Old Sep 2, 2012 | 08:25 AM
it shifts into drive but doesn't stay in long and goes back out, i only put 10 miles on the car since i bought it guess thats why i got so cheap huh, it also has 456 rears that gotta go other than that everything seems fine it looks like new inside and out, it came off the ground a few feet when i drove it the first time and knocked a hole in the oilpan which ended up being bad schocks i replaced them with eldecbock shocks and solved that problem, gonna change the rears to 370's i think whats your opinion? i wanna just go to shows and cruises etc but might want to race it once in awhile, thanks for your input though, oh i forgot to mention it's a 68 roadrunner
Old Sep 2, 2012 | 08:52 AM
What do you have for a shifter? Some of the B&M (example) ratchet shifters work "either way" for a reverse or conventional valve body, because the ratchet works either way. But the B&M "pro stick" will have to have a different detent plate installed, which you can order.
So far as the transmission, no idea. Depending on who made the valve body, I might be interested. PM me when/ if you decide.
Old Sep 2, 2012 | 08:53 AM
I don't think you have to change out the shifter. I have a regular shifter in mine with a reverse manual valve body. I just have to remember the shift pattern. I would go with 355 gears to make it more streetable.
Old Sep 2, 2012 | 08:57 AM
it's a b@m quicksilver shifter and it's a ratchet shifter
Old Sep 2, 2012 | 09:08 AM
A set of 3.55 or 3.73 gears would be much better. Maybe a wheelie bar too
Old Sep 2, 2012 | 05:15 PM
First ? Check the fluid level. Converting Just swap the valve body is the main change. Don't try to undo the mods just swap it. There may be other mods ? depends on who built it . Also for street you may need to change the tq converter
depending on stall speed
Old Sep 3, 2012 | 10:02 AM
I believe those work "either way." You should be able to download the destructions
In fact, here
http://www.bmracing.com/wp-bnmcont/uploads/80683.pdf
Old Sep 5, 2012 | 07:21 PM
In fact, here
ok tx it goes in the shop thursday the man does all the tranny work for my buddies that race so I'm sure it will be done right it should work with the automatic valve body
Old Sep 5, 2012 | 10:44 PM
By the way the kick down linkage is probably missing So check with Boulcher ? Performance for a kick down cable kit or Lockar VERY IMPORTANT no kickdown is the quickest way to destroy the trans
Old Sep 6, 2012 | 07:40 AM
Go with the Mopar Bouchillon Performance kickdown and not the chebby Lokar stuff.
Old Sep 7, 2012 | 04:20 PM
Gorts 5th's Avatar
Question
so wats up with the slot in some kick down linkages
Old Sep 8, 2012 | 06:39 AM
thanks a million! i spoke with the man and he said he didn't
get to drive my car yet but did notice all the linkage is missing to change it back to fully automatic and said they don't make aftermarket linkage thats hes aware of and I might spend alot of time to find it I might be better of leaving it as however i'm hoping this linkage you showed me is whats he talking about, I'll tell him Monday after he drives the car and knows whats wrong with it I might be able to switch it back after all
Old Sep 12, 2012 | 04:23 AM
Gorts 5th's Avatar
Smile
i will post some pictures for a cable set up my brother made for his trany
Old Sep 12, 2012 | 05:13 PM
Gorts 5th's Avatar
Smile
this is a choke cable he used with some other parts for his kick down you ll recognized some parts
Attached Thumbnails tranny trouble-img_20120831_111135.jpg   tranny trouble-img_20120831_111744.jpg
Old Sep 15, 2012 | 05:42 AM
ok, tx for the pics i just heard from the shop the tranny is shot and needs rebuilt, I'm getting it rebuilt and i need a new converter so I'm changing it back to a fully automatic the shifter can be used but I need the kickdown linkage which I'm sending for from Bouchlinn's should be all done by next week
Old Sep 15, 2012 | 05:48 AM
the valve body is fine but the tranny needs rebuilt I don't know whether you were interested in the shifter or valve body? i can use my shifter with the fully automatic but the valve body is gonna go i don't know make it is but can find out and also make sure its ok if thats what you want it's not going to be of any use for me I'm sure we can work it out if thats what you wanted
georgefla
Nov 11, 2008 01:59 AM
scampdude
Oct 20, 2008 06:06 PM
71RR08
Aug 14, 2008 07:36 PM
1972newport_sportsman
Jan 27, 2008 02:04 PM
slow70duster
Jun 29, 2007 02:55 PM
