clutch problem
Old Oct 30, 2010 | 01:42 PM
pops1967GTX's Avatar
clutch problem
clutch pedal only returns half way. need to use my foot to bump it up to finish.
Old Oct 30, 2010 | 01:47 PM
DakotaWill440's Avatar
clucth pedel or bracket could of snapped or bent
Old Oct 30, 2010 | 02:22 PM
rr69half6bbl's Avatar
first check the return spring, it goes from the bell housing to the clutch fork rod. small spring. bout 4 " long. if thats good, then check the adj. rod for the clutch, You may have just burned your clutch down t the point you need to apply more pressure.
Old Oct 30, 2010 | 04:23 PM
Thanks..checked linkage & spring seem to be ok...I think I'm at the end of the adjusting rod ..I haven't adjusted one in years not sure if I'm correct. also is there a spring on the Zbar ?...any threads on proper clutch adjustment for A833 big block....thanks
Old Oct 30, 2010 | 04:39 PM
I dont know of any threads. i always use the factory repair manual. If your at the back end of the rod, then yes, your out of adjustment. No theres no spring on the z-bar. one end gets the clutch pedal rod, the other end gets the adj. rod.
Old Nov 2, 2010 | 07:00 PM
D100Guy's Avatar
interesting...i am having the same problem i have a little more rod adjustment left...will see how much more i can adjust in the morning.
Old Nov 4, 2010 | 04:57 AM
D100Guy's Avatar
well....i adjusted the nut on the clutch pedal rod almost to the end and now the clutch pedal comes all the way back up as before ....however the return spring even though it seems to work does not look that great...I will replace it...and now i can get it in gear as before the adjustment i could not while the engine was running.
Hey Pops1967GTX how old is that spring?...the original? I would change it just to eliminate it out of the equation as springs loose there stored energy over time.
Old Nov 7, 2010 | 08:23 AM
Changed spring, looked like it was for A body application. adjusted clutch, its at the end of the rod. it returns fine ...might need clutch soon no more adjustment left.
perussi
Jul 7, 2015 11:27 AM
1cerberus4u
Apr 18, 2008 06:55 PM
bigbadsrt
Mar 21, 2008 09:32 AM
gotdust
Jan 31, 2008 02:41 PM
gotdust
Jan 31, 2008 02:32 PM
