oil dipstick no reading
i have a oil dipstick showing just a bit of oil on the end
i just replaced the oil pan seal and the seal needed for the windage plate
same seal.
i put 5 quarts in i dont have what i believe is the 7 inch
i have the other i believe is a 5
is the another available
does anyone know the lenght of a oil stick for a 5 inch pan
should the stick go in till it hits the bottom
than work my way up in some way
now for the dumb question
i put oil in the big hole on my valve cover ....just checking
its a new vehicle me
440 engine i think early 76
thanks for the help
same seal.
thanks for the help
I wanted to touch base.
Adding another 3/4 of a quart did the trick.
when i did the change i also replaced the pan gasket. When i did this i let it sit for a few days, I wanted to give the pan a new paint job.
Im thinking every last drop of oil could of dripped out causing it to need a bit more.
Thanks guys!!
Thanks guys!!
dzltd02
10-28-2008 09:25 AM
